Results 1 to 6 of 6
Thread: Interior door
    Interior door
    I have a set of freud entry door bits And I have configure them for interior doos. My question is. As a general rule, how much smaller do I make the door from the opening? This is all new I have not had a door there before. Thanks
    Tim, I believe the common approach is to make the door 1/2" narrower than the finished opening it's going into. I've seen other references saying the rough opening should be two inches wider and taller than the door, but I don't remember the specifics about how the rest of the space is taken up by the trimwork.
    Take this all with a big ol' grain of salt though...there are other guys here who know a lot more about interior door installation than I do. They'll probably be chiming in pretty soon.
    RO= 38x82 for a 3/0x6/8 prehung door.
    if you build to fit a hole the door size depends on your jamb.
    i prefer to build "standard" sized doors and jambs.
    12,264
    Wow Todd if i understand you correctly thats an inch either side.
    over the size of the door.......if a person makes the jambs 3/4" that only leaves 1/4" to plumb the door on each side.
    12,264
    Thanks Todd now its clear for a dumb as like me.
  1. Interior decorator
    By Leo Voisine in forum Off Topic Discussion
    Last Post: 03-02-2014, 04:57 AM
  2. Interior painting question
    By Ron Jones in forum Off Topic Discussion
    Last Post: 11-16-2010, 12:15 AM
  3. Latest interior door with double sided carving pics
    By Garry Smith in forum Flatwork Project Showcase
    Last Post: 02-08-2010, 07:43 PM
  4. Tearout interior of bowls
    Last Post: 08-10-2009, 12:16 AM
  5. Interior Closet Door
    By scott spencer in forum Flatwork Project Showcase
    Last Post: 11-26-2008, 12:33 PM
