Results 1 to 8 of 8
Thread: Slow down router
    Mar 2009
    Lincoln AR
    142
    Slow down router
    I've made a jig to make flutes in my bowls and stuff, but here is my problem. I keep burning the wood. I have a speed reducer I use on my shaft driver cutter but it stills burns it. I am using a trim router which will only take about a 1/8 bit.
    Am I destined to use a larger router just can't get the speed slow enough. I put a lot of work into this set up I hate to 13 it and do it by hand.
    Thanks ,
    Bill, have you tried anything like this?
    http://www.mlcswoodworking.com/shops...d_control.html
    Also, this is probably a silly question, but are your bits sharp? Dull bits can contribute to burned cuts.
    17,475
    i would agree on the dull bits... i ran into that this wknd myself ran a cut and got burn switched cutters and the burn was gone
    9,077
    I think you've got your answers; proper speed and good cutters should get you good results.
    where is the burning occuring?
    if it`s at the stop/start ends of flutes then it`s all about technique, if you`re getting burning along the length then it`s probably a dull bit?
    "trim routers" can spin as fast as 30K rpm.....most round-nosed bits are designed to spin 20k....if you`re using an 1/8" bit look to see if you can find a single flute instead of a two-flute bit?
    chip clearance is the most important thing when using a router.......the c.n.c. guys will confirm this mathamatically but ol` woodbutchers know the correct "feel" for working a bit/motor combination......
    my gut tells me that if you`re spinnin` a two-flute bit in a laminate trimmer you`ll really need to be moving it through the wood quickly to provide propper chip clearance?
    you could try directing compressed air at the cutting edges while you cut to remove the chips.
    Mar 2009
    Lincoln AR
    142
    Mcmillan in the first sentence i said I was using a speed reducer. easy to read over stuff, I do it all the time. (good site though)
    The bits new but it has many flutes and may be part of the problem. I just think I'm going to have to go my air grinder (aint tools great).
    Thanks
    Evans your gut need a few more flutes in it the one flute sounds like a good idea . Most folks don't realize it, but a one blade propeller on a boat is the most effective. Of coarse it doesn't here but ya can't do it because of balance.
    It burning nearly every where, I know about stopping for a instant with these things, especially Cherry.
    The air sound like a good idea I take pretty shallow cuts, I'll try that. I do that when machining metal.
    Thanks
    Mar 2009
    Lincoln AR
    142
    Mcmillan I owe you an apology I went back to the site and it say they go to (0) mine is a HF and doesn't.
    No worries, Bill. I wasn't sure in your first post if the speed reducer you mentioned was the same type of device I was suggesting.
  1. Slow Learner
    By Jim C Bradley in forum Off Topic Discussion
    Last Post: 01-28-2014, 03:56 AM
  2. very slow today
    By Frank Fusco in forum Site Questions and Test Posts
    Last Post: 01-14-2011, 05:45 PM
  3. dog-slow again...
    By Art Mulder in forum Site Questions and Test Posts
    Last Post: 04-24-2009, 02:44 PM
  4. Slow, but sure.....
    By Bill Arnold in forum General Woodworking Q&A
    Last Post: 07-22-2007, 04:06 PM
