Results 1 to 6 of 6
Thread: The Ultimate Jack?
    Perth, Australia
    42
    The Ultimate Jack?
    A year ago I received a selection of timbers from my Galootaclaus (on OldTools List). A length of Ebony went to infill the Brese small smoother kit (and there is sufficient over to infill a St James Bay Thumb Plane kit). There is a block of Padauk. And there was this piece of Mesquite ...
    I have been waiting to build a jack plane around a blade I bought last year. It is 2" wide and 5/16" thick D2. This is very abrasion resistant and could make a super jack plane for use on Australian wood.
    This could be The Ultmate Jack!
    The design is a mix of tradional vintage England with Malaysian influences. Mesquite body with Jarrah tote and wedge.
    The razee body is 15 1/2" long, 2 3/4" wide, and 2" high at the mouth. This keep the centre of gravity low. The plane weighs 1.5 Kg (3.3 lbs).
    The mouth is set wide for a thick shaving. The bevel has not yet been cambered. It will have a radius of 8".
    The blade does not use a cap iron, and the wedge design keeps the mouth free ..
    I should have a full tutorial on building the jack up on my website in a few days.
    Regards from Perth
    Derek
    Articles and reviews at www.inthewoodshop.com
    Man, if that plane works half as good as it looks, you're in great shape. Beautiful work, Derek.
    Derek, that is one nice piece of work, I'm sure you will enjoy using that plane every time you pick it up
    5,322
    Superb work - as usual - Derek! That's some beefy iron you used. Where'd you get it?
    Perth, Australia
    42
    Hi Jim
    Not the same iron (no longer on sale) but try here for HSS: http://www.woodworkforums.com/showthread.php?t=100632
    Regards from Perth
    Derek
    12,260
    Ooooh I hope you can see me drooling over that plane and all the others on your site. Man its a work of art. I can stare at those pictures all day long.
    What great work.
  1. How NOT To Use A Pallet Jack
    Last Post: 12-12-2014, 10:03 PM
  2. Skeeter and Jack !
    Last Post: 10-13-2011, 09:14 PM
  3. New playmate for Jack
    Last Post: 06-26-2009, 07:53 PM
  4. Mitre jack
    By ken werner in forum Old Ads
    Last Post: 02-15-2009, 12:50 AM
