Results 1 to 5 of 5
Thread: Chuck jaws
    Mar 2009
    Lincoln AR
    142
    Chuck jaws
    Hi it's me again. You know those triangle plates that attack to your chuck so you can finish the bottom of a bowl.
    Are those lathe specific or well they attach to other chucks.
    I have a ONEWAY TALON.
    THANKS
    Sacramento, CA
    1,367
    They generally are chuck specific because they need to match the screw pattern. I think they're generally called Cole Jaws and maybe some chuck manufacturers are interchangeable (I think some one way and nova jaws mix and match nicely).
    I made a set of my own with a little mouse pad and some plywood:
    Jason Beam
    Sacramento, CA
    30,014
    Bill, the jaws typically can be used on different chucks of the same brand. For example, the jaws you have now on your Talon will fit the Oneway Stronghold, but I don't think they will fit any of the Nova chucks. There are some chucks (like at least one of the ones Grizzly sells) that are a close copy of other brands, so they can accept the other brand of jaws. I believe some or all of the Vicmark jaws will fit the Grizzly chuck.
    One thing to keep in mind is that the jaws are manufactured in a set, and the set should be kept together. I have two sets of the Nova 50mm jaws, but I don't intermingle the jaws. They are very close to the same, but not exactly.
    30,014
    Ah, if you're talking about the Cole jaws like Jason pictured, then he's right about them being chuck specific. (Or you can make our own like he did.)
    Mar 2009
    Lincoln AR
    142
    Thanks guys, it as I thought.
  1. Nova 75mm Long Nose Chuck Jaws - anyone using these ?
    Last Post: 12-14-2012, 02:29 PM
  2. Tech Talk with Craft Supplies on Chuck Jaws update
    Last Post: 05-08-2009, 05:18 AM
  3. Rasum Frasum Grizzly, need chuck for vicmarc jaws.
    By Rick Huelsbeck in forum General Woodturning Q&A
    Last Post: 04-13-2009, 02:16 PM
  4. SOLD: Barracuda2 Chuck plus Large Flat Jaws
    By Mike Henderson in forum Old Ads
    Last Post: 11-27-2008, 05:15 PM
  5. Putting Jaws on a Nova 2 Chuck
    By Jay Lock in forum Turning Tool Questions and Show & Tell
    Last Post: 10-10-2007, 02:56 AM
