Results 1 to 10 of 12
Thread: Couple of Mission style chairs for the commision
    Here is what I have come up with for the Priest and decon for the commision. The taller one is 50" Tall the other one is 40" tall. The seat will be upolstered in the same fabric as the pews.
    As alwas your coimments and suggestions are welcome.
    Attached Files Attached Files
    I am thinking of pitting a slight taper on the insides of the legs to lighten them up a bit.
    Dec 2008
    falcon heights, minnesota
    5,609
    if it were me don, those chairs are good to go!
    benedictione omnes bene
    www.burroviejowoodworking.com
    North West Indiana
    6,098
    Don, those will be fantastic!! Please take the time to document the process and work involved. I am green with envy!
    Jon
    Quote Originally Posted by Jonathan Shively View Post
    Jonathan,
    I plan on boreing ya'll with the entire build all 8 pieces. I don't have a steamer for the bent spindles so I guess I'd better think about building one.
    Sep 2007
    Plainwell, Michigan
    4,857
    I was wondering on the bent stiles, but if you don't have access to a steamer it sounds like you are ready to build one. The design for the chairs are RIGHT on Don. Please bore us/me. I am so enjoying/lookin' forward to what you come up with on this build
    Odessa, Tx
    1,813
    Don, the design for those chairs is really neat and unique as well. Some folks just make a long box out of cedar planks with a hinged door on one end and a hole in the other end to inject the steam. Others have made them out of 6" PVC. In either case, you need some cross pieces to slide your material on to keep them elevated so they get even heat/steam on all sides. Some have used a large teapot type kettle but one fellow bought a metal gas can and dedicated it to that use and it really looked good and he was satisfied with it's performance. Tilt the steamer and inject the steam on the low end.
    Waiting patiently to be BORED
    Looks great Don!
    new york city burbs
    10,188
    Im not questioning how you are going to achieve the bent angles, youve mentioned steam.
    If it were me, (it wouldnt be, because I wouldnt attempt something as difficult), since you mentioned oak.
    Couldnt you just take, lets say for example, a piece of 12/4 , maybe 6 inches wide,if the bend is 3 inches wide from end to end, cut a template out, then trace and cut it out on the bandsaw. Cut all the boards first,to the template shape, then fine tune them all together,(sand, plane) lets say 3 boards all 6 inches width.
    Then slice off 1/2 inch spindles and each one will be exactly the same since they come off of the same piece of wood, or use one piece for each side of chair, so each spindle on each side is exactly the same?
    Am Im totally off the mark, is my idea anywhere reasonable?
    Allen,
    I thought about that, That would be the Sam Maloof approach, The idea is not off the table but, That would produce a lot of waste. When I get chair frames made I'll revisit my options.
  1. Chairs........ Mission Accomplished!
    Last Post: 08-28-2011, 01:56 PM
  2. Making 2 Mission style chairs for the commision - Final Picture
    By Don Baer in forum Flatwork Project Showcase
    Last Post: 07-26-2010, 10:52 PM
  3. White Oak mission chairs
    By Dave Black in forum Flatwork Project Showcase
    Last Post: 01-01-2010, 12:08 AM
  4. Alternative design for Mission style Chairs
    By Don Baer in forum Designs, Plans and Sketches
    Last Post: 08-10-2009, 01:56 AM
  5. Couple of Tables for my commision
    Last Post: 07-25-2009, 10:35 PM
