Results 1 to 10 of 10
Thread: Sharpening a Bedan
    Zushi, Japan
    739
    Sharpening a Bedan
    Just curious if anyone is using a 1/2 inch Bedan and if so what is your method of sharpening this tool to a fine edge? Do you flat grind on a stone and then hone or do you put it on the grinding wheel. Do you grind the bevelled edge or just hone the top? I ask because the bevelled edge is quite long and putting this on the grinder creates a rather large hollow grind.
    Charlotte, NC
    1,487
    Al, please excuse my ignorance, but what is a Bedan?
    Zushi, Japan
    739
    Charlotte, NC
    1,487
    Spinny tools, Gotcha! I have an old Dunlop lathe that my dad gave me. Needs to have one of the bearings replaced. I need to get that done since I would like to take a crack at turning. I'll probably be asking you guys questions when I do get it going!
    15,811
    Alex, took me a day to find it, but here are the pics from J-F Escoulen's Demo, of his Bedans.........
    and remember, they are used like that, the bevel is up!
    J-F said that if you don't like the skew, you will hate the Bedan
    Zushi, Japan
    739
    Stu,
    Skews me and thanks for the pics. After I got it I went and put a hollow grind on it at the wheel. I think though this chisel is best sharpened flat with a diamond stone or wetstone. I haven't really used it that much in the versatile way that J-F used it but do like it.
    15,811
    Skews me.........
    I've got a boat load of spindle tools on the way, so we shall see how I get on with that stuff
    A while back, I bougth a 3/8" square parting tool, I intended to make it into a Bedan, but I've not gotten g-round to it.........
    Zushi, Japan
    739
    Well I've got a plane load so we'll see whose gets here first.
    15,811
    OK, mine is actually FedEx....
    BTW, I resharpened my 3/8" parting tool into a Bedan, and had a go at some soft pine I had laying around..........FUN STUFF!!!
    Yep, all the cut and shapes you see on that chunk of pine were made by that one tool, the Bedan!
    It is a bit catchy, but as it is spindle work, the catches are not catastrophic
    Fun tool, I put a straight flat grind on it, but I think a hollow grind will work better.
    Here is a pic of an egg that J-F Escoulen turned with a Bedan in about 2 minutes flat..........
    Going to be experimenting with this tool for some time to come!
    Zushi, Japan
    739
    Hey man that is some pretty slick turning for just one tool. Uually I have six or seven on the bench in a pile.
  1. Sharpening help
    By Harry Miller in forum General Woodturning Q&A
    Last Post: 05-22-2014, 06:08 PM
  2. Sharpening sharpening
    Last Post: 07-29-2010, 05:24 PM
  3. Sharpenig a bedan
    Last Post: 04-08-2010, 02:08 PM
  4. The Bedan
    Last Post: 06-03-2008, 07:00 AM
  5. Home made Bedan
    By Terry Quiram in forum Turning Tool Questions and Show & Tell
    Last Post: 03-12-2008, 01:37 PM
