Results 1 to 10 of 16
Thread: Strange question re: stabilizing tobacco
    Hardinsburg, KY
    277
    What would you use to stabilize tobacco?
    I just had a thought to turn a cigar pen using a cigar. I've never heard of anyone trying it. Neither have I ever heard any discussion of tobacco and reactions with any glues or finishes. I'm going to experiment with this but wanted to know if any of you have tried anything like this or know of any bad reactions I need to look out for. Told you it was strange. Still, maybe I've come up with the next $1,000,000 project. (Hmmm, I wonder if Rush Limbough would like one for about $75.00?)
    Working flat so I can play round,
    Doug Miller
    Repentance Is The
    Prerequisite For
    Gods Forgiveness
    Hardinsburg, KY
    277
    Should have been clearer. I'm going to start with a cigar.
    Doug Miller
    Repentance Is The
    Prerequisite For
    Gods Forgiveness
    Red Deer, Alberta, Canada
    618
    No idea how to do it but that is a cool idea, Doug!
    Why has common sense
    become so uncommon?
    My Woodwork Site
    30,014
    Doug, I think I'd look into a casting resin and a pressure or vacuum pot. I think the pen turning forums will have a lot of info on resin casting, but I can't recall any of the appropriate URLs. Hopefully one of the pen turners here will chime in.
    Hardinsburg, KY
    277
    I thought of a vac pot, but I'm not going to buy one for this one project. Grea idea though.
    Doug Miller
    Repentance Is The
    Prerequisite For
    Gods Forgiveness
    5,321
    Quote Originally Posted by Doug Miller View Post
    Make one from some 2" PVC pipe. Cap one end, and glue a threaded coupling on the other, then use a threaded plug, and a vacuum hose fitting. Easy and cheap enough for a one-time use. Throw it away when you're done, or even clean it out for re-use later.
    Tellico Plains, Tennessee
    4,351
    There are several guys on the IAP that do castings... I've actually had the same thoughts as you, casting a cigar to make a cigar pen, but I don't do any casting, don't have any of the necessary equipment plus I am more or less cutting back on pen turning...
    Check with Jeff Taylor, Curtis Seebeck(The Mesquiteman), Ed4copies, The oklahoman or just look up casting and should find number of threads on casting.. There are lots more, just first names that came to mind.
    http://www.penturners.org/forum/forumdisplay.php?f=4
    Chuck
    Tellico Plains, TN
    Hardinsburg, KY
    277
    Great idea, Jim. However, I don't have a vacuum pump. Is there a way to draw vacuum with out a pump in this small vacuum chamber?
    Doug Miller
    Repentance Is The
    Prerequisite For
    Gods Forgiveness
    Dec 2008
    Portland, Oregon
    1,898
    I've used my food saver vacuum sealer with bags to do small veneering projects. It has a hose attachment, don't know it it would pull enough vacuum for your situation, but something to consider.
    Jesus was a Woodworker
    lutefisk capitol, USA
    485
    A brake bleeder from your local Humvee dealer(Harbor Freight) should do the trick.
  1. Stabilizing pen blanks
    By Jim Burr in forum General Woodturning Q&A
    Last Post: 01-10-2014, 03:11 PM
  2. Stabilizing.
    By Drew Croy in forum General Woodturning Q&A
    Last Post: 06-04-2011, 03:00 PM
  3. Kind of a strange hardware question....
    By John Pollman in forum Off Topic Discussion
    Last Post: 04-15-2010, 11:32 AM
  4. stabilizing set-up
    By Frank Fusco in forum New Tools
    Last Post: 05-31-2009, 11:05 PM
  5. Stabilizing ring?
    By Barry Richardson in forum General Woodturning Q&A
    Last Post: 02-05-2008, 02:31 PM
