Results 1 to 8 of 8
Thread: third bench and lathe platform done!!
    Dec 2008
    falcon heights, minnesota
    5,610
    well gang, today was a real work day here. had to run over to home depot to pick up the plywood for the lathe platform. the nice thing about both of these projects is that aside from the hardware and the plywood, the lumber was free. the bad thing was that even with compensating, i'll have to shim up a touch under one of the casters to get it to ride level. darned slightly twisty recliamed wood! oh well, back to the fun. the third bench went together pretty good, and will work just right for the sander and the planer. i did some rearranging on the one bench, and i can get the bandsaw and the shaper on it with minimal fuss. also, moved the belt/disk sander from the table saw bench to the other bench as well. with this move, i should be able to keep my planer/jointer on the table with the table saw. darned busy day!
    Attached Thumbnails Attached Thumbnails new bench and lathe platform parts.JPG   ready to start.JPG   parts sorted out.JPG   parts cut to length.JPG   fully assembled bench.JPG
    benedictione omnes bene
    www.burroviejowoodworking.com
    Honolulu, Hawaii
    1,103
    I loke your benches Dan, and may have to build one soon.
    But, what is that fittysix chebby there in the first pic? Yours?
    Ah,,,to live in Paradise!
    Registered voting member
    Dec 2008
    5,610
    glad you like them tony, they're quick, easy, sturdy, and easy to make and adapt. no, that's my brother's 56. i have my projects, and he has his....
    Honolulu, Hawaii
    1,103
    Dan,
    I have a small bench I have been using for a while, although it is not really suited for what I am doing on it. Building one like yours will be much better, especially because I can install casters on it. That is not an option on the bench I have now at all. I am space restricted and mobility is a plus.
    Now I have to go scrounge up my materials and get motivated.
    Thanks.
    Aloha, Tony
    Dec 2008
    5,610
    only thing you have to remember with this table tony, is that you need a minimum of 4" up from the bottom of the leg for the lower cross member, and notch the opposite side of the leg from the top down, for the upper cross member. other than that its pretty easy. i add something across the legs at the bottom, from side to side, for 2 reasons, stability, and extra shelf space.
    Calgary, Alberta, Canada
    1
    Hi Dan,
    My first post on this forum. Lots of lurking tho.
    I'm curious why you had the cross members on opposite sides of the legs?
    These look like good heavy duty movable (casters) benches for power equipment (Bench top Drill Press, etc).
    Robin
    Dec 2008
    5,610
    hey robin, welcome aboard (no pun intended)! originally the benches from these plans were intended to be stationary, and having the cross members on each side provides stability for the legs. to make them mobile, i added the base parts to the bottom of the legs, and added the casters. i didn't change the legs at all. the nice thing about this design, is that it is very adaptable. if you want a deeper bench, make the cross members longer. if you want a wider bench, make the stretchers longer. if you want a taller bench, make the legs longer, but remember the lower notch needs to be at least 4" from the bottom. this bench is not as deep as the first 2 are. the top on this one is 4 2x6's, and the first two are 6 2x6's deep. they are that deep because my table saw is a bit on the large side, and i wanted to have my jointer/planer along side of it. the other has the other tools i use set up around the perimeter, and there isn't much space in the middle. the third one i setup for just the drum sander and planer. this way i have everything i'll need handy on 3 mobile benches. also, they are held together with nothing fancier than 2 1/2" sheetrock screws.
    Dec 2008
    5,610
    if you want to see how i put the first 2 together, it's the thread "2 new workbenches!"
  1. Vega lathe copier video - a 6 minute bench leg
    By Bryan Cowing in forum Turning Tool Questions and Show & Tell
    Last Post: 01-24-2015, 07:13 PM
  2. rebuilding the lathe platform...finished!
    Last Post: 11-03-2010, 03:35 AM
  3. Platform bed
    By Al killian in forum Flatwork Project Showcase
    Last Post: 08-16-2008, 12:00 PM
  4. Lathe Bench
    By Wes Bischel in forum General Woodturning Q&A
    Last Post: 10-24-2007, 12:20 AM
  5. Lathe Bench Concept
    By Wes Bischel in forum Designs, Plans and Sketches
    Last Post: 10-23-2007, 01:49 PM
