Page 1 of 5 12345 LastLast
Results 1 to 10 of 45
Thread: Mission Style coffe table
    new york city burbs
    10,188
    Im not following any plans, just building it piece by piece, section by section, roughly 22x47 inch top, 18 inches high.
    Im using Ash. I have alot of it, and it was very inexpensive.
    I dont have much time this week do to the excessive heat, and next week Im working a 9 day stretch, so Ill just try to prepare some rough wood, Ive already prepared (jointed and planed) the leg pieces, and laminated some to get 2 inches square thickness.
    Ill work on the table top and the bottom shelf pieces this week, maybe glue it up also. Not sure how much I can tolerate.
    Neuro doctor was very specific yesterday with his comments on me pushing it in hot weather, especially using tools.
    Oh, on that note, btw, right after I finish the table, Im going to go into the hospital for 2-3 days(I havent given him a answer, Im not thrilled about hospitals) for a treatment called IVIG, hopefully make me close to 100% so I can get back to banging out furniture and redoing some of my house.
    Ill shoot pics as I move along this build slowly.
    I love the dark stain that was showed on ash recently, would love to copy that color, but this table is going into an all maple colored furniture area, so Ill have to keep it light finish.
    Ash is a tough wood, very, very hard. Im learning that today.If I had a lathe, Ill spin a baseball bat out of it right now.
    new york city burbs
    10,188
    planed up alot of wood, wasnt as easy picking best matching boards for top.
    did the best I could figure out.
    Attached Thumbnails Attached Thumbnails wood stuff 1104 (Medium).jpg   wood stuff 1105 (Medium).jpg   wood stuff 1106 (Medium).jpg   wood stuff 1107 (Medium).jpg   wood stuff 1109 (Medium).jpg
    Looking forward to seeing this one come along, Allen.
    new york city burbs
    10,188
    all the parts are cut to size, all the glue-ups are done except for one glue up for both sides table top.(I wanted to final plane both sides at same time to get even thickness, then glue up and sand my way home, only have 13 inch planer)
    I have not yet cut mortise and tenons, Ill set it all up today, but the heat has shut me down today. Just going to set up mortise attachment and clean up so I can get mortise and tenons cut tomorrow.
    The legs are 2.25 inches square, glued up 3 pieces, planed and jointed, the rails are 3/4 inch while the stiles(spindles, dont know what to call them, slats?) between the upper and lower rails on the side are only 1/2 inch, I thought the thickness difference looks a bit better overall.
    The bottom rail, will not be seen, it will be under center of bottom shelf, screwed into center board of bottom shelf.
    Cleats will be added to bottom rails on sides and a hole on each side will be elongated and only a screw put into underside of bottom, no glue on sides, only glue on center board as I figured to allow for any movement of wood.
    Thats it, this is what it will look like, mission style, minus the inches for the tenons.( I was about to taper 2 sides, the bottom 3 inches of the legs today, but decided against it)
    Id like to put a very small chamfer on the bottom of the legs, so they dont crack or split, maybe 1/8th of an inch, 45 degrees, but dont want to use the router, any suggestions? I dont own a plane that does that, not sure if I can do it with the smoother plane.
    Attached Thumbnails Attached Thumbnails wood stuff 1112 (Medium).jpg   wood stuff 1113 (Medium).jpg   wood stuff 1114 (Medium).jpg   wood stuff 1115 (Medium).jpg
    Constantine, MI
    7,892
    I really like the way this is turning out. Good job!
    www.wrworkshop.com
    Dec 2008
    falcon heights, minnesota
    5,610
    use your table saw allen, with the blade tipped over to 45 degrees. that's what i do with all my furniture legs.
    benedictione omnes bene
    www.burroviejowoodworking.com
    new york city burbs
    10,188
    might have too.
    17,475
    allen a smoother could do it but its alittle large for the job.dont u have a good low angle block plane. like a 60 1/2? that would do it or a sanding block would too.. a scrap piece of hard wood with paper wrapped around it..
    new york city burbs
    10,188
    I own one plane. I think Im going to just sand a tiny bevel, just to knock the edge off.I dont want to be too aggresive and have any chipping problems with the tablesaw blade.
    Dec 2008
    5,610
    easier to use the table saw allen. once you find the mark to take of 1/8", you're good to go with the rest.
  1. Mission Style Wine Rack
    By Gary Zimmel in forum Flatwork Project Showcase
    Last Post: 09-06-2011, 10:52 AM
  2. Mission Style End Table
    By Dave Haynes in forum Flatwork Project Showcase
    Last Post: 07-20-2009, 07:11 PM
  3. Mission Style Bench
    By scott spencer in forum Flatwork Project Showcase
    Last Post: 05-24-2008, 05:02 AM
  4. Mission Style Mantle Clock
    Last Post: 02-15-2008, 02:12 AM
  5. Mission Style Frames
    By Sean Wright in forum Designs, Plans and Sketches
    Last Post: 05-29-2007, 05:24 PM
