Results 1 to 8 of 8
Thread: plywood edges
    Mar 2009
    Lincoln AR
    142
    plywood edges
    I made a about 8x10 funny saying (scroll sawing) so I decided to frame it seeing it was nothing special I decided to make it out of plywood. I router a small round over on the outside and inside of the frame. Being Plywood I decided to paint it, but the edges on the outside and inside are drinking up all the paint giving a dull look. Is there a sealer I can use to quench their thirst for paint?
    Thanks Bill
    Primer is a great help. Also some use Glue white or yellow glue will seal the edges. And of course the old favorite, Shellac or sanding sealer.
    9,077
    Bill's about got it covered.
    May 2009
    Poway, CA, near San Diego
    174
    Hi folks,
    I like "Durham's Rock Hard Water Putty"
    It's a powder you can mix with water to any thickness you want.
    Make it like thick cream, and you can brush it on the edge. Sands easily to a nice smooth finish.
    Bob
    Another vote for Durham's. It's easy to sand, and stays where you put it.
    Floydada, Tx
    1,941
    I use sizer. Basicly thined yellow glue. It helps seal up the end grain and it is quicker then putty.
    As previously stated shellac will stick to anything and is very fast drying. You can also tint it to come close to the color of your paint.
    Jerry
    Mar 2009
    Lincoln AR
    142
    Thanks for the tips
  1. Something on Edges of Plywood Lathe Bolw Steady
    Last Post: 03-05-2013, 09:44 AM
  2. Planing/smoothing edges of hardwood frame on plywood edges?
    By allen levine in forum Neander Woodworking Q&A
    Last Post: 07-03-2010, 01:32 AM
  3. sanding edges and ends
    By Mark Kosmowski in forum Jigs and Fixtures
    Last Post: 06-13-2009, 10:48 PM
  4. Straight edges on sale
    By Ken Garlock in forum Hot Deals
    Last Post: 01-23-2008, 03:30 AM
  5. Radiusing all edges of a cube in Sketchup?
    By Neil Clemmons in forum Designs, Plans and Sketches
    Last Post: 12-27-2007, 04:35 PM
