Results 1 to 9 of 9
Thread: How do you fix tearout?
    688
    Question How do you fix tearout?
    Somehow on every project I make, there's a little piece of tearout from the planer or handplane that I don't discover until the joinery is all done and I have a lot of time invested in the piece. Usually the tearout is a little more than can be sanded off, but not bad enough to fit in a plug or anything.
    So what do you do? Epoxy, CA? Do you add some sawdust to the glue? Famowood or some other filler? Is there a silver bullet I don't know about (hope, hope)?
    Steve Clardy Guest
    I use famowood usually.
    I used to use glue and sawdust, but if the mixture has too much glue, it will show up.
    535
    My two favorites...
    Are hide glue and sanding dust, and glazier's putty and transtint or other coloring agent. The finisher who showed me the putty trick also used metalic paint from HD to get a kind of irredescent look that helps keep it from looking like this flat patched area in an oil finish. The putty works better for big dents than tear out.
    John
    Central NY State
    3,362
    Steve and John, does that work with a clear finish?
    Jesse, I am really glad you asked this question. It happens to me all the time, it seems.
    Ken
    535
    I rarely stain, so clear is kinda what I'm geared for. Hide glue doesn't seem to resist oil finish the way pva does, though I've never made a detailed study of it. Some experimentation is still in order.
    John
    Steve Clardy Guest
    Dust and glue. Yes on clear finish.
    Have to mix it so it is so dry, it will barely stick.
    Too much pva and it shows
    I was just reading Teri Masaschi's new book on finishing
    "Foolproof Wood Finishing" for those who love to build and hate to finish
    FoxChapel Publishing
    http://www.amazon.com/Foolproof-Wood...e=UTF8&s=books
    On pg 39 she suggests using CA and sanding to repair tear out.
    I think this is a pretty good book, you might sneak a peek at it if you've got a Borders or Barnes&Nobel nearby.
    Jay
    Austin, Texas
    1,347
    I'm a PVA glue and sawdust person... sanding dust for the smaller sins, actual saw dust for the larger. If I am into the finishing stages, I mix the sanding dust with lacquer rather than glue.
    Hide glue is a good idea, but I keep forgetting to try it, since it is out of sight in the closet.
    Charlie Plesums, Austin Texas
    15,582
    Quote Originally Posted by Charlie Plesums View Post
    ...............................Hide glue is a good idea, but I keep forgetting to try it, since it is out of sight in the closet.
    Huh, in your case it is called "Hide" glue, as it is.................................. "hidden".................
    Ok, I'm easy to amuse
    I've used CA fairly well, but the thicker stuff, the gel like one, the thinner one was just a bother.
  1. vertical panel raiser tearout question
    Last Post: 11-25-2010, 02:55 PM
  2. How to prevent tearout when planing
    By Don Baer in forum General Woodworking Q&A
    Last Post: 06-26-2010, 04:30 AM
  3. Tearout interior of bowls
    Last Post: 08-10-2009, 12:16 AM
