Results 1 to 7 of 7
Thread: Vacuum chuck?
    East Freeetown, Massachusetts
    3,020
    Vacuum chuck?
    Has anyone ever made a vacumm chuck, using a shop vac for a vacumm source?
    Dec 2008
    Portland, Oregon
    1,898
    Don't know about using a shop vac, but here is a "how to" on making a vacuum chuck. Maybe something in there you could use.
    Vacuum Chuck
    Jesus was a Woodworker
    3,020
    Mmmmmm
    Sorry Dan.
    That's not what I am talking about.
    Not for a lathe.
    It's more like a vacumm table - but used for holding flat pieces while machining them on a CNC router.
    Leo,
    I vagualy recall someone did it but I can't for the life of me recall where I saw it. I'll try to find it and post it for U
    5,172
    Having had a CNC and using vacuum clamping for holding flat work, maybe I can lend some insight.
    First, Vacuum chuck is a term used by woodturners. Vacuum clamping is the term used by flat woodworkers so you might want to re-post to get the right people interested in your post.
    Second, go to www.veneersupplies.com for lots of vacuum clamping and vacuum systems information.
    A ShopVac can help to more quickly evacuate air from a vacuum bag for veneer clamping but it cannot survive constant vacuum pressure for hold down purposes. The motor will burn up. Vacuum pumps are readily available from surplus sources. Systems include more than just the pump. The above web site will further enlighten you.
    Years ago I taught vacuum clamping technology in a woodworking program at a Southern California community college. I cannot add to what Joe Woodworker has for vacuum systems, technology, or information. I think it is that good.
    But that is just my 2 cents worth. I did not use it by itself on the CNC table. I did use it in conjunction with positive holds to keep things in their place. Let me know if you want further information in this area.
    Leo, a shop vac will not work how you are thinking, as Carol correctly points out the motor will be burned up, this is because the motor relies on the air flow of the vacuum to cool it, once you suck the back down to nothing and try to hold a vacuum, there is no air flow, no cooling and soon afterward, no shopvac motor
    I think that you can get a good vacuum pump used for about $50 from a surplus shop.
    OK, I checked, I think >> THIS ONE << is the one that most guys buy, and it is $54 plus shipping.
    30,017
    ...OK, I checked, I think >> THIS ONE << is the one that most guys buy, and it is $54 plus shipping.
    That's similar to the one I got from them a year and a half ago, but not exactly the same. Mine has a bit more vacuum (25 inches vs. 20) but fewer horsepower (1/5 vs. 1/4). That said, I suspect it'd work fine for either vacuum clamping or chucking.
  1. Vacuum Chuck
    By Jim Krager in forum Neander Tool Questions and Show & Tell
    Last Post: 09-23-2011, 07:02 PM
  2. Vacuum Chuck
    Last Post: 04-03-2010, 05:16 PM
  3. Vacuum chuck?
    By John Ryan in forum Turning Tool Questions and Show & Tell
    Last Post: 08-10-2008, 10:22 PM
  4. another vacuum chuck system
    By Clark O'Neill in forum General Woodturning Q&A
    Last Post: 04-03-2008, 12:41 PM
  5. Vacuum Chuck ?
    By Ned Bulken in forum Turning Tool Questions and Show & Tell
    Last Post: 11-02-2007, 01:14 PM
