View Poll Results: Are you a pins first or a tails first maker?
Voters
49. You may not vote on this poll
  • Pins first
    9 18.37%
  • Tails first
    21 42.86%
  • I'm so good at dovetails that I use both at random
    0 0%
  • I use my router jig so I don't care
    19 38.78%
Results 1 to 10 of 28
Thread: Dovetails, pins first-tails first complete different techniques.
    Catalunya
    4,632
    Hi there.
    As you know each day before working on whatever project I’m working on I cut a set of dovetails to keep on practising and improving my technique.
    I take it as some sort of warming up exercise and honestly, I doesn’t take more than 10 or 15 minutes and it pays off.
    A couple of weeks ago as I want to master all techniques I started making two sets instead of one, one cutting tails first and the other pins first.
    What was my surprise when I found that they are completely different techniques.
    If I use the pins first technique with the saw settings or distances from the lines that I use on the tails first the joint becomes too tight, up to the point of splitting the wood.
    I’ve found that I need to split the line, then I get a perfect joint, better and more consistent in result than with the tails first technique.
    On the other hand, if I use the pins first distances on the tails first technique the joint becomes too loose and the joint lines are too evident.
    Before finding this I thought that there wouldn’t be any differences and that it was a matter or personal preference using one system or the other.
    Has any of you found the same or is it that my sawing technique is poor? Now I have to decide for one of them because switching from one to the other will lead to errors for sure.
    Las but not least, I hope to have explained myself properly and by no means would I want this post to be the beginning of an endless debate between pins first or tails first.
    Just for my info feel free to vote on the poll
    Best regards,
    Toni
    I like to do tails first, I find I can design the dovetails to fit the piece of wood better by doing tails first, I've only ever seen one person cut dovetails in person, me, so who knows, I might be all wet about this
    10,604
    I really really admire those with the talent and patience for delicate hand work. Unfortunately I don't have a ton of either. So I use my good old Rockler dovetail jig.
    I two find that I get better fit by doing the pins first. Now mortice and tenions that another debate. I won't go there.
    I do tails first as I find it easier to hold the tails against the end of the "pin" board to mark it.
    Jan 2008
    Austin TX
    405
    I used to do pins first, but found it easier to do tails first. I'll explain, when I cut the pins first my sawing for the tails must match an angle on the verticle plane. When I cut the tails first, there can be slight differences on the verticle plane without any problem, since the pins are cut to match. The pin angle is with the saw verticle, but rotated on the horizontal plane, which is much easier to handle for me. I'm sure it reflects a lack in sawing skills, but it is really much easier to produce decent results.
    For what it's worth.
    Lee Laird
    Austin TX
    I may have to change my vote in a few days since loml got me a dovetail jig for my birthday..
    You got me . Coffee on my monitor .
    Central NY State
    3,374
    I learned from Tage Frid's books. Pins first. Once I tried tails first, though, I have come to prefer it. When making a box, I'll tape the sides together, and cut both sets of tails at once. This saves time, gives me a wider platform to saw on, and provides better matching of the tail placement and size. Toni, your observations are very interesting.
    Thomasville, GA
    5,994
    I use my Incra jig. So far, I've only done half-blind dovetails and they're a snap on my Incra.
    Bill Arnold
  1. Replies: 20
    Last Post: 08-16-2014, 03:27 AM
  2. For Steve Southwood - Tails & Pins
    By Bill Satko in forum Handtool Project Showcase
    Last Post: 04-04-2014, 11:53 PM
  3. Hundereds of Dove Tails
    By Tom Hoffman in forum Flatwork Project Showcase
    Last Post: 05-20-2011, 07:55 PM
  4. mortise techniques
    By Mark Kosmowski in forum General Woodworking Q&A
    Last Post: 07-03-2009, 02:24 PM
  5. Two Toboggans (illustrating steam bending techniques)
    Last Post: 01-10-2007, 12:26 PM
