Results 1 to 10 of 18
Thread: Siberian Elm Bowl Set
    This pair of bowls came from some local Siberian elm that my wife bird dogged for me a few blocks away from the house. I roughed these out back in May (here's the thread) and finished them a couple weeks ago. (They both still need buffing, but I'm in no rush, so I'm letting the finish sit for a while before I buff them.) I've been putting off taking photos of these because the mama bowl is too big for my photo tent. I finally decided to heck with it, I wanted to show them to someone.
    The baby bowl ended up at 12 3/4" wide by 1 1/2" tall. Real simple form with just the figure in the wood doing the real work. This was a piece of crotch wood, but I didn't get the feathering centered very well, and it only showed up in the baby bowl. The finish is 3 or 4 coats of Formby's Tung Oil finish. I'll buff and wax it sometime between now and the next show.
Name:	Bowl 073 - 09 800.jpg
ID:	35612 Click image for larger version.
Name:	Bowl 073 - 01 800.jpg
ID:	35613 Click image for larger version.
Name:	Bowl 073 - 03 800.jpg
    The mama bowl is 18" by 4". It's the biggest one I've done so far. These are obviously not gallery-quality photos, since the bowl is a bit too big for my backdrop. The pics will still get the idea across. (I really need a bigger backdrop. I have a 4' x 4' photo tent that I've never used because I don't have a good backdrop for it. Maybe I need to do the trick I've seen on SMC ages ago and just make some big gradient JPG files and get them printed on one of the wide format printers at Kinkos.) This one has the same finish as the little one. Oh yeah, the crackes were filled with black epoxy.
Name:	Bowl 073 - 06 800.jpg
ID:	35615 Click image for larger version.
Name:	Bowl 073 - 07 800.jpg
ID:	35616 Click image for larger version.
Name:	Bowl 073 - 05 800.jpg
ID:	35617 Click image for larger version.
Name:	Bowl 073 - 04 800.jpg
    And one shot of the happy family...
Name:	Bowl 073 - 10 800.jpg
    I've got another pair about this size that are roughed out and dried. I'm just giving myself a bit of a break before tackling them. Once it dried, this wood dulled my tools faster than anything I remember turning, and even though the roughouts were very dry, the wood moved a lot from stress release as I finish turned it. I finish turned the outside of the big bowl one evening, and when I went back out to the shop the next night, there was over 3/4" of an inch in variation in the rim. I had planned to make it kind of chunky (a la Jeff Bower) but by the time I got the round again, the walls ended up about 3/8" to 1/2" thick. By then it was getting pretty flexible, and with all the cracks it had, I didn't get too heroic about perfect finishing cuts. I spent a lot of time with the 80 grit gouge to get them smooth, especially on the big one.
    Now all I've gotta do is find someone who wants to buy a bowl that's too big to fit on a shelf.
    Comments and critiques are welcome, as usual.
    Mason Michigan
    455
    Incredible wood!
    Good call on not being a hero.
    "Small Change got rained on with his own 38"
    Tom Waits
    810
    17,475
    looks good vaughn,, i got some feather in some walnut that someone needs to make use of the feathering doesnt go very deep does it?
    Jul 2007
    Des Moines, IA
    854
    Vaugh, those are beautiful. I like the form and the wood is awesome.
    Apr 2008
    Texas
    199
    Very nice Vaughn I really like the wood.
    Alan
    Thanks, Larry. Yeah, the limited amount of feathering I've seen hasn't gone real deep. Sure is cool stuff when you can hit it and keep it.
    How big is that piece of feathered chocolate that's wasting away at your place? Flat rate box or bigger?
    Hardinsburg, KY
    277
    Very nice Vaughn. Makes no difference that the 80 grit gouge was used heavily. The result is fantastic. The lines are sharp and clean. I assume, even though you never said it, that you used your coring system. Is that right? Which corer did you use?
    Working flat so I can play round,
    Doug Miller
    Repentance Is The
    Prerequisite For
    Gods Forgiveness
    Jul 2007
    DSM, IA
    5,719
    Pretty bowls Vaughn! The grain on those are awesome.
    Maybe you could build a shelf to fit the big bowl and sell it with the bowl.
    My Website
    Certainly nice work, as usual, that elm is very near the Keyaki that I use so much, it too is hard to turn, really dulls the tools fast, but the effort is usually worth it.
    Fine work indeed!
  1. A bowl and a bowl tweaker
    By hu lowery in forum Lathe Project Showcase
    Last Post: 11-03-2015, 04:07 PM
  2. Siberian Elm NE Bowl
    By Nate Davey in forum Lathe Project Showcase
    Last Post: 02-09-2014, 02:32 PM
  3. A Little Siberian Elm Fruit Bowl
    Last Post: 12-02-2010, 05:24 AM
  4. Shallow Siberian Elm Bowl
    Last Post: 10-15-2010, 11:35 PM
  5. Bent my bowl gouge.. a 5/8" bowl gouge
    By Chuck Ellis in forum General Woodturning Q&A
    Last Post: 09-01-2010, 12:57 PM
