Results 1 to 8 of 8
Thread: How to clean parallel clamps
    Apr 2008
    Butte Montana which is 1/2 way between Purgatory and Heaven
    170
    Does anyone know how to remove dried wood glue from parallel clamps - I've tried water, mineral spirits and sandpaper and it's not working
    Jiggs Elphison
    I used a heat gun and an old awl. After cleaning them up once, I embraced the infinite value of masking tape ;-)
    an old sc rew driver and pry it off
    If it's old enough, sometimes a hammer works to knock it off. Like Glenn, I did it once, and now I use wax paper between the clamp and the workpiece if there's a chance glue will drip on the clamp.
    Parrallel clamps are Machinists tools so I guess you are talking about Hand Screw Clamps... (Wood clamps with two concentric screws) Most are already treated with either oil or finish. so you should be able to chip the glue off with a sharp chisel , then give them a coat of Paste wax to prevent future sticking.
    Bill, the standard red Bessey (and similar) clamps are also called parallel clamps...
    Amazon Example
    Oh for the shame of it... Parallel Clamps, See I are too poor to own them from Bessey... but the same comment is true, those PVC heads are easy to clean with a chisel and Vinegar is a solvent for most glues. PS Vaughn, I was in the garage and saw the chunk of Ambrosia Maple I promised (a year ago) I will wrap and send ASAP...
    Sep 2007
    Plainwell, Michigan
    4,857
    A scraper also works well. Keep them coated with a light coat of paste wax and they will clean up very easily.
  1. Irwin 24" Parallel jaw clamps $21.99 ea
    By Ned Bulken in forum Hot Deals
    Last Post: 06-24-2013, 10:23 PM
  2. Craftsman Parallel Jaw Clamps
    By Tom Blank in forum Jigs and Fixtures
    Last Post: 12-06-2011, 03:17 PM
  3. woodcraft parallel clamps
    By Geoff Barry in forum Hot Deals
    Last Post: 01-17-2011, 05:22 AM
  4. Craftsman Parallel Clamps (New)
    By Jack Lemley in forum New Tools
    Last Post: 10-30-2009, 01:22 PM
  5. Irwin Parallel Clamps
    Last Post: 07-13-2009, 11:30 PM
