Results 1 to 2 of 2
Thread: shaper platform
    Dec 2008
    falcon heights, minnesota
    5,609
    shaper platform
    with my shaper's motor hanging inside of, and well below the flanges that held it to the base, i have found that it would be right awkward to use now that it is off of it's base, and would sit at an angle on the bench. so i decided to make a platform for it to sit on. i measured the inside dimensions of the flanges (that's the other side of the out side larry ), and the distance of the motor beyond the bottom of the table. the platform was easy enough to make, as 2x6's on end, with a 3/4" plywood base gives more than enough clearance for the motor. i cut notches in the framework for the power cord and the on/off switch. it's not pretty, but it's functional.
    Attached Thumbnails Attached Thumbnails shaper front.JPG   shaper back.JPG   shaper platform.JPG
    benedictione omnes bene
    www.burroviejowoodworking.com
    Not pretty, but functional is good in my book Dan!
  1. Anyone had a look at the Platform CNC kit
    By Rob Keeble in forum New Systems and Builds
    Last Post: 11-01-2015, 08:17 PM
  2. Queen Platform Bed - Completed - Finally!!!
    By Bill Arnold in forum Flatwork Project Showcase
    Last Post: 04-16-2014, 06:24 PM
  3. Platform Bed with Nightstand
    Last Post: 04-14-2012, 06:13 PM
  4. third bench and lathe platform done!!
    Last Post: 08-06-2009, 01:53 AM
  5. Platform bed
    By Al killian in forum Flatwork Project Showcase
    Last Post: 08-16-2008, 12:00 PM
