Results 1 to 10 of 11
Thread: Input requested on router table
    Jan 2008
    Austin TX
    405
    I currently have an old craftsman router table (short aluminum with a ridged top surface) that is pretty lame. I've wanted an upgrade for a long time (since the mid-80s) but haven't made or bought one. I just saw an interesting one over at the Grizzly site. It's model Number G0528 Router Table . Does anyone have any experience with this product? I'd appreciate some thoughts on this.
    (I've got an older Makita 3.5hp router, an old Sears 1 3/4hp piece of junk, and a Triton 2 1/4hp. Just to lay the ground-work)
    Thanks in advance,
    Lee Laird
    Austin TX
    Lee
    I made my router table in the winge of my TS. It has served me well. I can use the TS fence for a router fence and since space is a premimium in my shop I like it. I have made several jigs that fit on the fence and feel that based on my limited space it is the best I can hope for. That is unless I wion the lottery and can build the untimate shop.
    Jan 2008
    Austin TX
    405
    Don,
    Thanks for your input. Your shop sounds very similar to mine. I had thought about doing the same as what you've done. Presently, I'm so crowded that instead of installing the extension table between the 52" rails, I slipped my 1100 cfm dust collector into that space. I know I'm shot down if and when I have to cut some wide sheet-goods, but I'm not needing it at present. I'd actually planned to get the shorter rail version of my SawStop, but my wife talked me into getting the biggest one. I'm not certain I can even make room for the Grizzly unit I was looking at, but seems every time I get something new, I'm able to slip it in somewhere.
    Regards,
    Lee Laird
    Austin TX
    In that price range there is a lot to choose from. I would collect the thoughts of some of the members here before moving forward. The DC footprint and the RT would be about the same. Adding a router table wing could solve your potential sheet goods issue by moving the DC to where the Griz table might stand(?).
    I put a wing on and eventually built a cabinet under it and gained some storage and DC for the table. There is only fence dust collection on the Griz table so you would need to box it in or let 'er blow.
    I have the bosch enclosed cabinet which was around $160 from blowes and it's more than good enough for what I do.
    パトリック
    daiku woodworking
    ^deshi^
    neoshed
    Thomasville, GA
    5,987
    I've had a variety of router "tables" over the years, starting with a Craftsman tabletop unit. I've built my own tabletop unit and a cabinet built around a Rockler manufactured top. I've had an insert in the extension of my Jet tablesaw. When I built my current shop, I wanted plenty of space around the table saw that would also serve my table router work.
    Here's what I have now.
    The router support is two layers of 3/4" MDF with surrounding support built like a torsion box. The Incra jig base mounts in six 1/4"-20 threaded inserts in the table. In addition to being a great router table, I can lay a full 4'x8' sheet on the assembly prior to running it through the tablesaw.
    Bill Arnold
    Jan 2008
    Austin TX
    405
    Glenn and Patrick,
    Thank you both for the info. I'll see what the Bosch unit looks like.
    Bill,
    My wife and I have talked about making a shop in the future, so I'll definitely log away your info. l like the layout and functionality of your shop. Thanks for the info.
    I'll continue to look around. In the end, I may just build one so I'll have the features that I desire. Luckily, I'm in no hurry. I can always fall back on the old Craftsman unit, at least for a little while. <grin>
    Regards,
    Lee Laird
    Austin TX
    Craftsman also sell a rebadged version of the bosch table I have and it was actually about $15 more.
    パトリック
    daiku woodworking
    ^deshi^
    neoshed
    Like Patrick, I have the Craftsman re-badged Bosch as well. (Craftsman 26608 and Bosch RA1171) I picked mine up for $50 a few years ago. The only complaint I have is the mounting plate is plastic and with a Hitachi M12V hanging on it, it sagged. I picked up the Bosch insert which is die cast aluminum. It is larger, so it will need a bit of rework on the top.
    When I was in my local Sears this weekend, they had theirs on closeout for around $150. If choosing between the two units, unless the price goes much lower on the Craftsman (like $50 ), I'd go with the Bosch to avoid the mounting plate issue. http://www.amazon.com/Bosch-RA1171-C.../dp/B000H14DLY
    Good luck sorting all the options!
    Wes
    Jan 2008
    Austin TX
    405
    Patrick and Wes,
    Appreciate the additional information. Good to know the difference between what sears is selling as theirs and the true Bosch.
    I don't know if anyone has the same Triton router that I have, but I haven't seen many of the produced tables that talk about matching up with the hole pattern of this router. Anyone know of a table that is a known fit for the hole pattern on the Triton??
    Thanks again to everyone and keep the info coming,
    Lee Laird
    Austin TX
  1. Router table router recommendations - What are your experiences?
    By Matt Hutchinson in forum General Woodworking Q&A
    Last Post: 11-11-2012, 04:27 PM
  2. Ryobi tabletop router table and router combo
    Last Post: 12-05-2010, 02:02 AM
  3. Rockler Router Table and Router Startup Special
    Last Post: 08-22-2008, 02:56 PM
  4. pool table/dining table input welcomed
    By Robert Schaubhut in forum Designs, Plans and Sketches
    Last Post: 05-22-2008, 02:31 AM
  5. Table Saw. Band Saw. Router Table. *** ALL SOLD ***
    By Rob Bodenschatz in forum Old Ads
    Last Post: 05-31-2007, 04:56 PM
