Page 1 of 4 1234 LastLast
Results 1 to 10 of 38
Thread: I'm so frustrated right now.
    May 2009
    Lafayette, Indiana
    2,380
    In the last few months I have put together what I thought was all the tools to start turning decent size bowls and such. I have purchased new gouges, a chuck, a lathe, and spent most of last weekend cutting up a large amount of walnut wood that was given to me. I've been feeling kind of foolish because I've spent so much time and effort in gathering all the stuff I needed but I wasn't turning anything. Well tonight I thought I would give this new wood a spin and so I took my first real good size piece of walnut and marked a circle on it. I then took it to my small band saw just to cut off the corners a little and WHAM...POW...my little 10" Craftsman bench top band saw flies apart. I never liked this saw anyway but I had hoped that it would at least cut, even a crooked cut would be ok. BUT NOOOOO.... So I went ahead and mounted the block (very square) on the lathe but it beat me up trying to cut it down so I gave up. I tried to use a circular saw but not much luck. SOOOOO.... now I need to find me a decent band saw. I'll have to search the threads here for recommendations. I would assume that I need to buy as large as I can afford but finding quality is going to be important too. I would guess something in the 14-inch range?
    Tom
    11,833
    If it fits your budget, go 17". You will love the decision.
    Otherwise, a nice 14" (Jet, Grizzly, etc.) will serve you very well. I have the Griz G0555 14 incher and will be putting a riser on it to cut over 6" pieces.
    Nov 2008
    Tampa & NC
    432
    I know how you feel.Like said,even if you have to wait a day or so to save up for it,get the best you can afford.To me this is one tool in the turners shop that you don't want to by cheap,as you will regret it later on.You may want to check Craigs list in your area.I have seen some good deals there.Good luck.
    3,132
    Tom, Frank gave you good advice on the bandsaws. Now if you just want to get back to turning,take your chain saw and cut off the corners.It woun't be as good as a bs will be, but it's a lot better than a square blank. If your blank isn't real thick i'll use my 12" miter saw and cut the corners off. Hope that might help get ya started, and please post pics.
    Steve
    Sorry for the frustration, but you've gotten good advice so far, Tom. The Grizzly G0555 and its brethren are good saws, and especially with a riser, are likely to be able to handle the sizes of blanks you're likely to be turning. As others have said, bigger is better, and used tools can be a good deal, too.
    For now, I'd go with Steve's advice and knock the corners off with a chainsaw and spin up some of that walnut. Once you have curlies flying all over the place, you'll almost forget about your bandsaw troubles.
    Here's an example of a few "chainsaw round" blanks that went straight onto the lathe. I only rounded the blanks that were bigger than I wanted to wrestle onto the bandsaw. (For scale, that's an 18" bar on the chainsaw)...
Name:	Woodward Elm - 12 800.jpg
    May 2009
    Lafayette, Indiana
    2,380
    Thanks for the advice guys. I guess the chainsaw will have to do for now. I've looked around tonight and do not see anything decent for sale in my area so I will have to just keep looking. I would not mind buying used, if I can find something in good shape.
    Tom
    Tellico Plains, Tennessee
    4,353
    Tom,
    Have to agree with advice todate.. go big on the BS if you can.. I have a Delta 14" without a riser yet, it's frustrating trying to put big blanks under it.... I do use my chainsaw to set up most of my bowl blanks...
    Vaughn,
    Those are some honking bowl blanks you got set up...
    Chuck
    Tellico Plains, TN
    May 2009
    Lafayette, Indiana
    2,380
    I did find this. Can anyone tell me anything about it good or bad. I e-mailed the owner for info. What about the price?
    http://muncie.craigslist.org/tls/1285934602.html
    Tom
    Nov 2008
    Tampa & NC
    432
    WOW,hope you get it.That looks looks like one heck of a good deal for 350.00.I would grab it up in a heartbeat ifn I were close enough.I'v heard a lot of good talk about em.Good luck.
    Hardinsburg, KY
    277
    Yep, like Ken said, Griz makes good bandsaws. This looks to be a pretty good deal.
    Working flat so I can play round,
    Doug Miller
    Repentance Is The
    Prerequisite For
    Gods Forgiveness
  1. I'm frustrated and need to rant....
    By Chuck Ellis in forum Off Topic Discussion
    Last Post: 01-27-2015, 05:31 PM
  2. Frustrated.
    By Drew Croy in forum General Woodturning Q&A
    Last Post: 11-08-2010, 02:13 PM
  3. frustrated with penn state ind....
    Last Post: 05-29-2010, 01:43 PM
  4. Frustrated with sketchup
    By Larry Browning in forum Designs, Plans and Sketches
    Last Post: 12-13-2006, 10:56 PM
