Results 1 to 9 of 9
Thread: how to get a grinding angle
    11,825
    There is talk of the Raptor set going on right now.
    I saw the link for the whole set and it has many angles.
    However, I need to figure out how to set a tool rest for a ten degree angle. Other than the "eyeball" method, I would like ideas.
    It is for the hollowing carbide cutters below.
    30,002
    Frank, if those are carbide, I don't think your grinder is going to sharpen them. I believe most carbide edges are sharpened with diamond stones. If they are HSS, then your grinder will be fine.
    As far as your 10 degree question, I've always just used my eye to match the existing grind on things like handled scrapers and scraper bits for my hollowing tools.
    Lake City, Florida
    498
    Frank, seems like you can cut a jig from scrap plywood -- You know the wheel diameter and the relation of the tool rest to the center of the wheel --
    something like this ...
    Tony, BCE '75
    11,825
    My misteak. I just went to the Don Pencil site and found that they are HSS. And, I was skeeptikel about sharpening carbide on my wheel also.
    A plus, much to the credit of Don Pencil's honesty. He actually suggests going to a machinist supply house and buying replacements for about $1.50 each instead of ordering from him. I find that just super refreshing in these days of tooth and claw competition. Good on you, Don.
    Cotswolds, UK
    629
    Frank, I use a set of simple templates:
    Attached Thumbnails Attached Thumbnails DSC02911 (Small).JPG   DSC02912 (Small).JPG
    Chas. just a traveller on the road of time.
    Bits & Pieces Gallery
    My Web Site
    11,825
    Quote Originally Posted by Chas Jones View Post
    That's good. Simple. I like simple.
    Thanks for the tip, I'll make up one of those in 10 degrees.
    U.K.
    112
    Thumbs up
    Me too, thanks Chas.
    Sacramento, CA
    1,367
    For me ... if I have something who's angle I need to repeat ... I mark the bevel with a sharpie and adjust the rest to "close" and test it by holding the cutter up to the wheel as though I'm going to sharpen - turn the wheel by hand and look to see if all the sharpie is removed. Works swell for me
    Jason Beam
    Sacramento, CA
    Goodland, Kansas
    4,834
    I do like Jason Frank. It works great. Takes 30 seconds to line it up.
    Bernie W.
  1. Grinding and Sharpening Jig
    By Jim C Bradley in forum General Woodturning Q&A
    Last Post: 08-28-2014, 04:46 AM
  2. CBN Grinding Wheels
    Last Post: 04-09-2014, 12:56 PM
  3. Grinding wheels
    Last Post: 09-04-2009, 11:17 AM
  4. grinding wheels
    Last Post: 04-08-2008, 12:07 AM
  5. which grinding wheels will I need?
    By Ned Bulken in forum Turning Tool Questions and Show & Tell
    Last Post: 03-30-2008, 04:33 AM
