Results 1 to 10 of 12
Thread: Disappointed Craft Supply Spur
    Palm Springs, Ca
    1,169
    Pictures below - bought some new tools one of which was a new spur center. According to the add it is very strong and meant to use on natural edge turnings etc - It resembles one for spindle stuff but the ad said it was super strong etc..
    Day off today and mounted up a mesquite blank - two wacks with a wood mallet and put it in with my new steb spur center in the tail stock and started turning - holding power is great and finished the bowl in the normal manner. Then took it all apart to reverse into my supernova and noticed the edges on the spur were bent..........I was not happy at all and plan on calling them on Monday to complain about it. I was told this would incrediably strong by the person taking the order and is far better than a two prong......I like CS but this just irritates me to no end.......ahhhhhh well ill let you know what happens
    Dan
    Central Illinois
    936
    YIPES! I thought the people at CS were more up front than some other folks. That said, even the best manufacturers have failures, it's how they AND their distributors take care of the problem.
    Just a thought; everything I read says that two wing centers are better that four. They don't seem to spin in the wood as much. Been thinking of trying one, but haven't got around to it.
    Bruce
    Bruce Shiverdecker - Retired Starving Artist ( No longer a Part timer at Woodcraft, Peoria, Il.)
    "The great thing about turning is that all you have to do is remove what's not needed and you have something beautiful. Nature does the hard part!"
    11,831
    That is a different style that the 'softies' I have encountered.
    It's a shame the steel quality is so poor.
    I don't know which brand is trustworthy as far as the common spur is concerned.
    I use the PSI knock-off of the Steb center but it doesn't hold very well. Spin City. I can't recommend it.
    Nov 2008
    Tampa & NC
    432
    Disapointed Craft supply spur
    Real bummer,1st off I don't believe you will have any trouble with getting a refund or replacement from CS.I have never seen one do that.I have a bunch of them from HF and even they hold up great.
    Goodland, Kansas
    4,834
    Thats to bad Dan. I don't believe you will have any problems getting your money back or a replacement. They have treated me well and have taken care of any problem I have had in short order and completely to my satisfaction. I have found today there are more problems with factory quaility control and wouldn't blame CS.
    Bernie W.
    Phoenix, AZ
    112
    I have a few drive centers, but I think this is the last one I will have to buy. Had it for a year or so and no problems so far. This one is from StubbyLathes USA, but I think others make something similar, including the ones that fit into various brands of chucks. The things I like are the size, the fact is uses threads rather than a morse taper (don't need to find something to drive out a morse taper), and that you can remove the spurs and point to sharpen, change how long they are, or make a two pronger. It will still spin in some soft woods, but does a whole lot better than any of my other drive centers. Also, if the spurs are TOO sharp (therefore thin), they will bend in really hard wood. I took a year to decide to buy it because it cost more than I wanted to pay, but I'm glad I did as I use it on almost every piece. no affiliation, just a happy stubby lathe owner.
    http://stubbylatheusa.com/Convertibl...Center.100.pdf
    Tellico Plains, Tennessee
    4,351
    I have a couple of 4 prong spurs that I picked up somewhere, don't remember when or where, but on both of them the spurs bent when I used them... I took the drive to the ol' belt sander, ground off the bent over prongs... it shortened the spurs slightly, but since I got into a little thicker metal on the ground down spurs, haven't had any problem since.
    It is a pain the postier portion of the anatomy though.
    Chuck
    Tellico Plains, TN
    Nov 2008
    Tampa & NC
    432
    Disapointed Craft supply Spur
    You just reminded me Chuck,but I took all of my spur drives and cut two of the cutters off and changed them to two drive centers,they seen to hold much better that way.
    30,014
    Bummer about the center. I'm sure CS will take care of things, though.
    I've gotten in the habit of tapping the 4-prong center a time or two with a mallet to mark the spur locations, then using an old beater chisel to deepen the slots that they go into. This seems to greatly reduce the amount of spin-out and slippage I see.
    Palm Springs, Ca
    1,169
    I agree with the comments and i am not faulting CS really but i am going to see what they will do tomm because it is not supposed to do what it did according to their advertisment. Ill let ya know how it turns out.....Dan
  1. two spur drive center?
    By Ned Bulken in forum General Woodturning Q&A
    Last Post: 01-02-2013, 07:38 PM
  2. These Animals are Disappointed in You
    Last Post: 04-21-2012, 01:15 AM
  3. Disappointed but not surprised
    By Robert Farmer in forum New Tools
    Last Post: 03-11-2009, 09:29 PM
  4. Time for a new spur drive... What to get?
    By Rich Tota in forum Turning Tool Questions and Show & Tell
    Last Post: 11-04-2008, 11:25 AM
  5. Very Disappointed
    By Bob Spare in forum General Woodworking Q&A
    Last Post: 02-28-2008, 09:43 AM
