Results 1 to 3 of 3
Thread: Rockwell contractor saw bearing
    Oct 2008
    Upstate S.C. near Anderson
    26
    How much work is involved in replacing the trunnion bearing on an older Rockwell contractor saw? It does look like some heavy lifting is involved. "Oh, my aching back!
    Jim
    Jim Evatt
    Jim,
    I did the arbor bearings on my Rockwell/Delta unit (34-400 series). It isn't fun, but can be a one man job. I pulled the motor with the plate and the extension wings. I unbolted the cabinet from the stand. Then I was able to turn the cabinet over on the stand by myself. Once on it's back it was easy to work on.
    Hope that helps,
    Wes
    Odessa, Tx
    1,813
    Quote Originally Posted by Wes Bischel View Post
    Jim,
    Hope that helps,
    Wes
    I used the exact same procedure on a late 50's model Craftsman Contr. saw.
  1. How do you choose a bearing
    Last Post: 08-07-2014, 09:53 PM
  2. Bearing Trivia
    Last Post: 04-26-2012, 07:48 PM
  3. Ball bearing Source
    By Bob Wiggins in forum General Woodworking Q&A
    Last Post: 06-22-2011, 12:06 PM
  4. Exploding bearing bit
    Last Post: 12-23-2007, 10:08 PM
  5. Bearing question
    By Jeff Bower in forum Old Iron
    Last Post: 08-02-2007, 04:22 AM
