Results 1 to 10 of 10
Thread: Dremel Multimax Tool Kit ?
    Floydada, Tx
    1,941
    I am in need of a tools that can trim plywood flush to the wall and seen this. The reveiws seems good, but we all know how that goes. Anyone use one? Or should I look at getting the Fein? I am trying to save my cash right now, but do not want to buy something that is not going to work well.
    Al,
    I recently picked up a Harbor Freight multi-function tool. For less than $40 it did the job - grinding out the grout in the tub surround.
    http://www.harborfreight.com/ there is a video on the title page.
    Just food for thought,
    Wes
    al,
    fein`s patent ran out.......i have no idea how well the dremell unit is made but if you are able to buy it from a no questions asked/return it for a working unit type store you should be able to use it to make money.
    i have an older pneumatic fein that i really find handy.
    I have the dremel and it's been fine so far for what I've used it on. I was massaging a couple of half lap joints in a arbour I'm building and I just needed to shave bits off here and there.
    It works great for sanding but it seems to go through paper in a flash.
    パトリック
    daiku woodworking
    ^deshi^
    neoshed
    I bought the dremel and have used it quite a bit during a bathroom remodel I'm just finishing up.
    It works as advertised.
    I've cut wood with it.....removed grout with it......
    Ken
    Odessa, Tx
    1,813
    Seems like a month or so back, one of he WW mags had a comparison of (i believe 4) of the kits like that. I think one was Fein, Delta or PC, Harbor Freight and Dremel. They seemed to cover them pretty well in their tests and the good/bad points of each. One or two could use the cutters/tools from another and the others couldn't. (just can't remember which mag it was in).
    I got one, Santa was involved, but I have not found it to be as useful as advertised. OK it will do a plunge cut and some detail sanding but as an all a round handy dandy time saver.... Nada! But, on the other hand, Last week I needed to install a cabinet in a room with corner molds covering poorly installed paneling. The saw sliced through the molding w/o a problem... I have found it a great asset for removal of the bottom of the door casement when converting to a Tile floor. Once I used it to cut a plunge cut into a wall for adding an electrical recepticle box.
    So, Yes it is handy and yes I would buy it again but to think it is a panacia of tools is stretching the envelope.... One thing that is a problem, when I was cutting the corner molding, I had to re-cut one piece and there was considerable distance to the next nail and so the strip vibrated along with the tool so no cut was made till I nailed down the molding to stop the movement.
    Floydada, Tx
    1,941
    Ok guess I get to go the BORG tommrow and get one. Thanks for the help.
    today only $60.00
    http://www.woot.com/
    Floydada, Tx
    1,941
    Just orderd it. Thanks.
  1. Dremel even getting in the 3 D Printer market
    Last Post: 01-03-2016, 11:16 PM
  2. Hegner Multimax 18 - SOLD
    By Rennie Heuer in forum Classified Ads
    Last Post: 12-07-2012, 03:23 AM
  3. Dremel 12V Lithium Rotary Tool Kit
    By John Marking in forum Hot Deals
    Last Post: 03-29-2011, 04:11 PM
  4. Good deal on Dremel oscillating multi-tool
    By Barry Richardson in forum General Woodworking Q&A
    Last Post: 09-04-2009, 01:18 PM
  5. Dremel Multi Max?
    By Jeff Bower in forum New Tools
    Last Post: 12-22-2008, 11:35 AM
