Results 1 to 10 of 14
Thread: Did i NEEEEED another drill press?
    Sep 2007
    St. Louis, MO
    583
    This found its way into the back of my truck on friday. I'm pleased as punch with the Walker Turner DP that i've been using for the past 9 years, but couldn't let this one go. My wife dutifully shook her head and rolled her eyes, then accepted the fate of being wed to an addict.
    It's a South Bend (known for metal lathes) 14" floor model. I think it's from sometime near the 50's and looks like it's seen light use. Someone slimed it with mint green at some point, but there's no rust to speak of, everything that should be loose is loose. Everything that should be tight is tight, and there are no missing or broken pieces.
    I dragged it down the steps, plugged it in, and it fired up nice and smoothly. There's a GE 1/3 hp motor, and the belt loosening / motor mount setup is a thing of simplistic beauty.
    I don't know when exactly i'll get to the rebuild - before spring i'm sure. There are a few things in front of it. If the bearings check out, it's actually in plug n play condition.
    There are already 2 drill presses in the shop - my WT 900 series, and a C-man 9" on the kids' bench. My thinking is to dedicate the WT to woodworking, puting a large table and fence on it. The South Bend would then be for everything else.
    Is my wife right? Am i a bit nuts? Asking this crowd, i already know you'll all back me up here. It's just that this goes a bit against my grain, keeping two identical machines when i could manage just fine with the one i've got.
    I'll get better pics up at some point.
    paulh
    Attached Thumbnails Attached Thumbnails 3k13oe3p55Qe5S35R598q9e2c986a81c21e5d.jpg   3m03od3pe5Ob5Pa5R598qe246ab78479e1daf.jpg   3mc3o73p75O35Re5Se98q2f6ea90416c31473.jpg
    Jul 2007
    DSM, IA
    5,719
    Well Paul, you probably didn't need another DP, but if you have room for it why not! Having one dedicated to wood working and the new (old) one for metal work and the like will be great.
    My Website
    Sep 2007
    Plainwell, Michigan
    4,857
    My brother would say only 3? He has 6 in his shop Paul He owns and operates a 1 man weaving loom business here in Michigan and each one is set up for a particular purpose for time savings. So are you a bit nuts Naw just a wood worker
    5,533
    That reminds me of shop class in Grade school... mostly cause of the industrial pea-green paint. I'm betting it was in some sort of school and/or military shop at one point and got a coat of 'the color' as a matter of course.
    Nice plan, re the dedicated metal and wood presses.
    -Ned
    11,833
    Mighty fine find.
    Odessa, Tx
    1,813
    Many times I've wished for two, one for Woodworking and one for the metal stuff. It seems that almost immediately after cleaning mine up after doing some metal work so I can do some woodwork on it, I suddenly remember one more thing I need to do in metal first.
    Don't worry, just ENJOY.
    5,322
    Quote Originally Posted by Norman Hitt View Post
    That's what I have. An older Powermatic used mainly for metal, and a nearly new Shop Fox radial that only sees wood. It's a good combination.
    Sep 2007
    St. Louis, MO
    583
    OK,
    so my logic - good or not - is shared by others. Thanks for the input everyone. I'll share pics when i get into the resto. right now, i'm mulling over paint options.
    Light machine gray and dark red???
    paulh
    Floydada, Tx
    1,941
    Pual as a freind I will help you out. You can store it at my place till you need it. Then you can come over and use it. Oh wait never mind I am shopless at this point, so I guess you should keep it.
    Sep 2007
    St. Louis, MO
    583
    Al - you're shopless?!?!? That's no fun. Are you in-between places? Do you still have your tools/machines?
    Not that it's all bad. I haven't had any time in my shop in months. Every time i walk through the basement, my machines call my name and taunt me.
    By the way, thanks for the magnanimous offer. Hopefully, i can repay the sentiment one of these days.
    paulh
    Quote Originally Posted by Al killian View Post
  1. My new (old) drill press
    By Tom Baugues in forum Old Iron
    Last Post: 03-09-2014, 02:01 PM
  2. What do you put under a drill press?
    By Jim C Bradley in forum General Woodworking Q&A
    Last Post: 05-29-2008, 07:45 AM
  3. My new old drill press
    By Carl Goreth in forum Old Iron
    Last Post: 04-28-2008, 03:14 AM
  4. Drill Press
    By Bernie Weishapl in forum Turning Tool Questions and Show & Tell
    Last Post: 08-04-2007, 04:39 PM
  5. My Dad's first Drill Press
    By Bart Leetch in forum Old Iron
    Last Post: 01-14-2007, 04:27 PM
