Results 1 to 4 of 4
Thread: Mortise and tenon Q's... Workbench base
    I will be making my M & T's today and thinking ahead to some of the next steps, some of these joints (leg assemblies) will be made using draw-bore M&T's how much of an offset is good for the holes(3/8")... ~1/16"?
    For the mortises that will accept the stretchers, would ~1/8in oversize in the vertical dimension be enough for a secure lock without putting undue stress on the tenon ends? I will be using wedges, 2 per end of stretcher. 5deg kerfs with a 3/8 hole at the end of the tenon to avoid splitting the stretchers.
    Forest Grove, Oregon USA
    290
    Hi Brent,
    An offset of 1/16" in really hard woods and one of about 3/32" in softer woods works well.
    A nickel [the money] is about .072" to .075" thick (3/32" is .094") and works as an offset gauge. A penny is .056" or a skosh more and works for using an offset of 1/16" [which is .063"]. At least those two coins are close enough for how accurately I can drill...
    The other joints, are these through tenons or fox-wedged [blind wedged] tenons?
    Take care, Mike
    Wenzloff & Sons Sawmakers
    688
    I watched a video on this very subject on the woodworking channel (www.thewoodworkingchannel.com) the other day. Chris Schwartz recommended an offset between 1/16 and 3/32, the latter being more in the range of timber framing.
    Thanks for the info on the draw bores, I would hate to have to drive a dowel with much more than that in offset. The wood is red oak. A bit much for a base but I have it and it was cheap!!
    The wedge tenons are used with thru mortises and the wedges are going into the endgrain. I still have to decide what I am going to use for the wedges, oak or something with a little contrast. May wind up going with walnut and pick up a dowel for use in the other joints.
  1. Round Mortise with Square Tenon?
    By Bob Beasley in forum General Woodworking Q&A
    Last Post: 10-01-2015, 02:59 PM
  2. Mortise Tenon ?
    Last Post: 08-23-2011, 01:42 AM
  3. 114 Mortise & tenon joints
    By Jim DeLaney in forum Flatwork Project Showcase
    Last Post: 04-14-2010, 10:48 PM
  4. Three Quick Mortise and Tenon Questions
    By Chris Marlor in forum General Woodworking Q&A
    Last Post: 05-25-2009, 03:47 PM
  5. workbench base
    By Brent Grooms in forum Flatwork Project Showcase
    Last Post: 01-23-2007, 05:25 PM
