Bob Gibson
- Merrimack, New Hampshire
Nothing that a few nuke plants wouldn't cure
The electric cars should not cause problems for the grid. The problem we have today is that electricity demand peaks about 10am and again at maybe 5pm.Jonathan
But that is the problem, there are a ton of people that think they need to decide what you drive. And then there is the issue that we run out of electricity most every summer. Remember brown outs, and the warning that grid that is near collapse.
Garry
[...] purely electric cars. [...] why not have the electric motor turn a generator? use batteries to get up to speed, then use the generator to turn the motor and recharge the battery?
Very low temperature is a problem for many batteries. For plug in hybrids like the Volt, when you have it plugged in the power line drives a heater (in addition to charging the battery) to keep the battery above a certain temperature.2 things about purely electric cars. 1, what about driving in places like here in minnesota, say, around late november to mid march. little things like severe subzero weather, running them, and what about heaters? the other is, why not have the electric motor turn a generator? use batteries to get up to speed, then use the generator to turn the motor and recharge the battery?
If I correctly understand what you're saying, this sounds like a classic "perpetual motion machine" proposition.
I remember drawing up a scheme like this as a teenager - minus the car. It was fun to think about. However, the 2nd (I think) law of thermodynamics says it simply can't work that way. At least, not for long. More's the pity.
Or flux capacitors.I believe until highly efficient, and inexpensive, solar panels are developed along with the discovery of super-conductivity, it just won't happen.
My opinion is that all electric cars are feasible today, but they have certain limitations. The advantage is lower operating cost - electricity is much less expensive than gasoline. The disadvantages are higher cost to purchase because of the battery cost, and limited range.Take it from one who knows an all-electric 'believer' first hand.
My son, who is a doctor, and a good one, is normally a very logical person. But, he is a 'greenie' and an all-electric believer. He has an order in for a Tesla when they start production. We recently debated (it might have sounded like an argument ) over the feasibility of all electric cars. Of course, no common ground was reached. I believe they will not be feasible for a couple lifetimes. He thinks the world is ready. He believes that all we have to do is install recharge stations everywhere. Street sides, parking lots, private homes, churches, just everywhere. I argue that would be impossible. Just the cost of copper wire (have you priced copper lately? ) would ruin any hoped for savings on running an electric car.
But, forget science and logic with these types.
Or flux capacitors.
Or flux capacitors.
I use the GM EV1 for a comparison. The problem everyone reported was the fear that you'd run out of juice before getting home. Drivers had to closely monitor the state of charge and carefully plan their trips because you couldn't just pull into a recharging station and "fill up" (recharging took a lot of time). That's just a killer for widespread adoption. The EV1 did encourage companies and government to offer recharging stations. The company I used to work for had three or four parking spots reserved for electric cars where you could recharge your electric car for free while at the office. Perhaps if more electric cars were sold more recharging stations would be available at places like Starbucks and others who stress their green creds.
Personally, I think the plug in hybrid is a better solution. Plug in hybrids don't try to eliminate the use of hydrocarbon fuel but greatly reduce it. And they only add load to the grid at night when demand is low. Recharging all electric cars during the day (as you son seems to want to do) will cause problems for the grid. The major disadvantage of the plug in hybrid is the higher initial cost because it uses both a battery and an engine - but that's the same as the Prius which has been very successful and is reported to be profitable for Toyota.
Mike
MikeThe electric cars should not cause problems for the grid. The problem we have today is that electricity demand peaks about 10am and again at maybe 5pm.
Electric cars will be recharged at night when the demand is very low. The chargers will be set up to not kick in until a certain time at night to avoid charging during peak times (of course, you'll be able to override that if you need to).
So electric cars will actually help the grid. They will help smooth out the demand for electricity and allow more efficient generation. They will not add to the peak demand unless everyone decides to charge during peak times.
Also, regarding the comment earlier about the cost of electricity for transportation compared to gasoline - electricity is MUCH cheaper on a cost per mile basis.
Note: Many locations have electricity cost of about $0.10 per kWh. For 0.25 kWh per mile, you'll pay about 2.5 cents per mile. For gasoline at $3.00 per gallon and a car that get 25 MPG, you'll pay about 12 cents per mile. To get the same cost per mile from gasoline (at 25 MPG), gas would have to cost about $0.63 per gallon.
Note2: One problem is how to get taxes from electric cars. Gasoline taxes pay for the roads we drive on. You may have seen proposals from governments to start charging for the miles driven, rather than use gas taxes. Many people object to that because lower cost (including tax) is an incentive to buy a vehicle with a higher MPG rating. Also, how is the government going to collect the tax? People would have to report their vehicle mileage on their state tax return or something like that. There would be a lot more avoidance than today with a gas tax.
Mike
[And please don't get me started on hydrogen. There are so many energy losses in the hydrogen system (from generation to use) that it will never be practical.]
No, I never said that all electric cars will be recharged at night. However, the suppliers of electric cars have stated that they intend to offer chargers that are programmed for charging during periods of low utilization, or offering chargers that can be controlled by the utility company to charge during periods of low utilization - in return for lower electric costs.Mike
You are making a lot of assumptions. I doubt that all cars will be charged at night. I can't see any way it can help the grid. Around here we use the excess at night to pump back up to a lake at a higher elevation then during the day they drop it back down thru turbines. And we have 3 mile island and peach bottom within 40 miles or so of us. In fact they are in the process of reworking 70 miles or electric poles to move a new generator in this fall. Comes from France.
