Results 1 to 10 of 18
Thread: 5 String bass guitar
    Central PA
    638
    Here is a 5 string bass I made from scratch. It is made from walnut and ash. It is a 7 ply laminated neck through body. There are 2-3/4" ash stripes between the neck and the walnut wings.
    PS the end vise on the bench that I made was made specifically for this project.
    Attached Thumbnails Attached Thumbnails DSCF0382.jpg   DSCF0386.jpg   DSCF0402.jpg   DSCF0455.jpg   DSCF0460.jpg
    Los Angeles, CA
    2,668
    Beautiful, Dave. Simply beautiful.
    Constantine, MI
    7,891
    Quote Originally Posted by Mohammad Madha View Post
    What he said + WOW
    www.wrworkshop.com
    10,604
    ditto, Wow
    Central PA
    638
    Here are a few more pics. I made the bass in march of 08 and just refinished it 3 months ago. I stripped it down and stained just the walnut and put a higher end bridge on it. The pics on the first post were from 08 and these pics were just taken a few minutes ago. There are also some pics of a case I made for it when I refinished the bass. The case was a whole other project by itself. I hot pipe bent 2 sets of sides and laminated them together. The sides were 1/4" and laminated the case sides are 1/2".
    Attached Thumbnails Attached Thumbnails DSCF1209.jpg   DSCF1210.jpg   DSCF1214.jpg   DSCF1218.jpg   DSCF1219.jpg
    499
    It's really great looking. The refinish job does look better.
    What's the finish ?
    Dec 2008
    Portland, Oregon
    1,898
    Dave,
    Beautiful Bass, I built a 12 string Guitar earlier this year, but haven't come up with a case for it. do you have any pics of the case build?? I'd love to see a tutorial on building one.
    Jesus was a Woodworker
    Central PA
    638
    The first finish was just shellac, the refinish is ebony stain on just the walnut and formbys tung oil applied by rag. The finish came out really smooth, I think there are 7 coats.
    I don't have any pics of building the case. It wasn't very hard, this was the first thing that I have hot pipe bent, I don't know how many people are familiar with hot pipe bending. I have never heard of it untill a few months ago. This is were I saw it done. http://www.finewoodworking.com/Skill....aspx?id=32490
    So basically I made a template out of plywood and formed the maple sides to it. I laid the bass on a large piece of paper and traced the shape that I wanted the case to be. I then took 2 pieces of 1/2" ply and screwed them together so I had a 1" thick piece. Then I copied the shape onto the plywood and cut out the shape. I then unscrewed the boards so I had 2 pieces exactly the same. I took those pieces and sandwiched 2x4s on edge between them, this essentially gave me a thick template that I could clamp to. I took some 3/4" x 5" maple and resawed it on the table saw and planed it to 1/4" I soaked the maple for an hour or so and used a hot pipe I made from a 3" copper pipe with a 200 watt bulb inside to bend the wood to fit the form. (I tried a pipe with a torch like the guy on the video used but I couldn't keep the temp down enough to keep from scorching the wood.) After I bent the pieces I glue laminated them together. The total length of the wood for the sides is 9', I didn't have anything that length so the added a 30" piece to make it up. I did a half lap joint to glue them together, The 30" piece is where the flat side of the case it. So after the sides were glued together I cut about 1.5" off the width, doing this created the "body" and the lid peices. I then used a rabbiting bit in the router table to do a rabbit that the plywood top and bottom fit in. I used 1/4" ply for the top and bottom and glued it in the rabbit. Then I spray glued fake leather on the outside and cut foam and covered it with cloth for the inside. and thats about it. I did make a bent glue laminated handle out of walnut and ash (matching the bass) and screwed it to the case. I think that covers the case, I hope this makes sense.
    Awesome-looking bass, Dave, and with the EMG pickups and the neck through the body, I'll bet it sings like a son of a gun. Great job, man. The case is one of the nicest I've seen, too.
    I have an old BC Rich Mockingbird that was made with a similar construction out of koa and maple. If (or rather when) I finally get around to building an electric guitar, I'd like to also do the neck through the body like that.
    11,833
    Now....that is a neat project. Well done.
    Do you run around with a guy named Shiraz?
  1. 5 string jazz bass build
    By Dave Black in forum All Things Musical
    Last Post: 02-10-2015, 01:15 PM
  2. Bass Guitar
    Last Post: 10-20-2014, 05:19 PM
  3. New 18-String Guitar
    By Vaughn McMillan in forum All Things Musical
    Last Post: 03-27-2014, 07:55 AM
  4. Bass Guitar From a Commodore 64
    By Dan Mooney in forum All Things Musical
    Last Post: 01-14-2014, 08:50 PM
  5. 3 string guitar
    By Jay Caughron in forum Off Topic Discussion
    Last Post: 07-22-2010, 01:33 PM
