Results 1 to 8 of 8
Thread: Planer Stand, All Kreg, All butt joints.. quick
    499
    I finally got tired of lifting my lunch box planner off the floor onto the table saw out feed table.
    So I looked around at the "extra" plywood I had and did some quick plans and came up with this.
    Looks like it might be a place to store jigs and such.
    It's real sturdy. I have to create a method to hook it to the outfeed table to make it NOT roll around. Those casters do not lock very well.
    The 1st picture is my SawStop with it's sliding table. This is GREAT. I was able to easily cut done a large piece of ply accurately and quickly. The sliding table made this a very easy project.
    Attached Thumbnails Attached Thumbnails IMG_2465.JPG   IMG_2469.JPG   IMG_2473.JPG   IMG_2474.JPG   IMG_2475.JPG
    Great job. I see no reason why it won't hold up... As for the casters, I have my planer mounted on casters and nexer lock them, see no need. I don't push on it during opperation as you simply lay the material on the table, introduce to the infeed roller and it does the rest by itself... Also with my tools I found that rubber casters one size too small are harder to roll and stay put when you want it and move when you need to. Correctly sized casters roll too easily.
    Manistique, Michigan
    297
    Good job. I need to do this for my planer and for my Ridgid spindle/belt sander. How high did you make the cabinet for the planer?
    Rich (the Yooper)
    "To the world, you may be one person, but to one person, you may be the world."
    "Common sense is not so common."
    Oct 2007
    Indianola, Ia about 12 miles south of Des Moines
    440
    That looks good. I was thinking of doing something like that for my planer, but hadn't got to it yet. I was wondering about making tables on both sides for long pieces.
    WOW... a saw stop AND a slider......I'm not worthy, I'm not worthy
    パトリック
    daiku woodworking
    ^deshi^
    neoshed
    499
    Sorry for the delay... The real job gets in the way.
    The dimensions are:
    34" wide
    22" deep
    29" high + 4" caster = 33" high
    The height is designed to be close to my out feed table on the TS.
    What I would change.
    This thing is really bigger than I wanted. I was going for stability.
    I would make it narrower. Just wide enough for you planer base. This would be about 20 1/2" for me.
    If you really needed the space you could make the width based on one side of the feed table being folded up when not in use.
    For me I am going to permanently mount a feed board thru the machine. I think I will be doing a lot of very thin stuff and it works just fine. I also think this will completely solve the snipe problem that I sometimes have.
    I am going to order two De-sta-co Clamps to connect it to my outfeed table so it will not move. Wheels just do not lock tight enough.
    Sep 2007
    Bloomington MN USA
    268
    This is my stand for my Dewalt Plainer. The only reson for showing you is for the base.IT locks firmly down. You can make it to any size demention with
    2x2s it came from Woodcraft.
    If you make a mistake it was part of the original plan!
    499
    I should have asked before I made it, but it just happened a couple of weekends ago.
    I had the ply and just started cutting.
    I will be handy for storing jigs an bulky stuff under it.
    Thanks for you post.
  1. Umbrella Stand: Behind the Door, quick weekend project
    By Art Mulder in forum Flatwork Project Showcase
    Last Post: 02-07-2013, 05:53 PM
  2. KREG UNIVERSAL STEEL STAND MOD #KRS1030
    By Jerry Cappeller in forum Hot Deals
    Last Post: 12-29-2011, 09:21 PM
  3. Quick and Dirty Drum Sander Stand
    By Vaughn McMillan in forum Flatwork Project Showcase
    Last Post: 10-12-2011, 11:53 PM
  4. Quick Hack - add drawers to the microwave stand
    Last Post: 06-07-2010, 02:30 PM
  5. Metal shop stand Rockler or Kreg?
    By Jack Lemley in forum New Tools
    Last Post: 07-12-2009, 01:29 PM
