Results 1 to 7 of 7
Thread: 3520B remote
    Monroeville, IN(Fort Wayne)
    111
    3520B remote
    OK a little gloat here, I just got my self a new Powermatic 3520B
    It came with the remote, but the wiring diagram doesn't match with what is there, does anybody remember what yours looked like?
    The schematic shows the white wire from the remote connects to the blue and white wires in the wire nut, and the black goes to #1 on the start stop switch.
    The lathe is wired different, the blue and white wires are connected to the start / stop switch at #2 instead of going into the wire nut, and there are 3 or 4 wire nuts taped in a bundle so I'm lost
    here's the http://www.osolnikmachinery.com/remo...tructions.aspx, if that helps
    my goal in life is to be as good a person as my kids think i am
    life is short, even in it's longest days
    30,014
    Woo-hoo! Congrats, Kevin! You're gonna love that lathe. (At least I love mine.) And the remote switch is a very handy addition. I use mine more than the main on/off switch.
    Like you, I discovered that the wire colors don't match the diagram. Without opening mine up, I'll try to describe how I did it. I'm going to assume you have a general idea about reading the wiring diagram. The wire colors on the remote switch don't matter at all. The switch simply makes or breaks contact, so the power can flow through it in either direction.
    Notice on the lathe that there are two wires coming from the push/pull power switch. You'll see one of them goes to the center tab of the forward/reverse switch, and the other disappears into the bundle of other wires. With me so far? That bundled wire is the one we're interested in.
    If you look at the diagram, the remote switch is simply making or breaking the continuity of that wire. To add the remote switch to the circuit, cut that wire a few inches away from the switch, strip the freshly-cut ends, then use wire nuts to connect the new stripped ends to the leads coming from the remote switch. That's all there is to it. When both switches are in the On position, the power flows to the circuits. If either of the switches are in the Off position, the power is interrupted.
    I should mention that the actual switch in the remote box doesn't seem to last very long. I wore out two of them within the first year or so of buying my lathe. When the first one stopped working, Powermatic gladly sent me a replacement for free. The replacement only lasted a few months before it died, too. Instead of bothering to get another one from Powermatic, I bought a different switch (another push/pull switch) and mounted it in the remote box. I got a 12v dashboard switch from a boating and ATV supply place on eBay. (I think it was intended for headlights or running lights.) The control circuit on the PM is only 10v, so any 12v automotive switch should work. Mine has worked flawlessly.
    I hope this helps, but let me know if you have any other questions.
    111
    Thanks Vaughn!!!
    Sounds straightforward enough, I'll give it try later tonight.
    North West Indiana
    6,098
    But good job on a great lathe!
    Jon
    111
    Worked like a charm Vaughn THANK YOU!!!
    Now to find time to use it
    30,014
    Quote Originally Posted by Kevin Brown View Post
    Worked like a charm Vaughn ...
    Glad to hear it. And I can relate to having the time to use it, but it's a big lathe...it's not going anywhere. It'll still be there when you get the time.
    Congrats on the Lathe and welcome to the Musterd club. I can also relate to the time thing. But I am optomistic one day I will loose my job or retire and have time
  1. Powermatic 3520B Lathe
    By Bill Satko in forum Hot Deals
    Last Post: 05-03-2010, 03:18 PM
  2. 3520B indexing
    By Paul Gallian in forum General Woodturning Q&A
    Last Post: 12-20-2009, 02:14 AM
  3. 15% off Powermatic 3520B Lathe
    Last Post: 11-14-2009, 12:58 PM
  4. Bed width top & bottom on PM 3520B
    By Nathan Hawkes in forum Turning Tool Questions and Show & Tell
    Last Post: 03-04-2009, 09:19 PM
  5. powermatic 3520b
    By Zack Massey in forum Turning Tool Questions and Show & Tell
    Last Post: 08-15-2008, 08:49 PM
