Results 1 to 10 of 18
Thread: drum sander snipe
    Hedgesville,WV
    158
    drum sander snipe
    AHHHHH... I'm ready to take a sledgehammer to this thing
    I have a delta 18-36" drum sander that I can't get to stop sniping my boards. It's set up as perfect as I can get it, but the sniping continues. it has something to do with the rollers, and I read nowhere in the manual about adjusting them.anyone here have any idea how to stop the sniping????
    Good grief this is frustrating... I can see it happening with my lunchbox planer, but not with this sander... totally unexceptable.
    Thanks....
    "Treat everyone equally,keep your word, and overlook peoples' mistakes...you'll make plenty yourself "..... spoken to me by a much wiser man than I.
    17,472
    james do you have extension tables for it?
    Catalunya
    4,632
    Excuse my ignorance, but what should I understand by sniping? That the sander takes a bite on the piece that is being sanded?
    Best regards,
    Toni
    Bellingham
    2,449
    Tony,
    The following link to Woodezine website has a great diagram that explains it very well. The site is copyrighted, so I refrained from just copying and pasting the diagram directly.
    <<Link>>
    Fixed the link!
    Catalunya
    4,632
    Quote Originally Posted by Bill Satko View Post
    Tony,
    <<Link>>
    Thanks but it doesn't seem to work, it give the "not found" error
    Best regards,
    Toni
    Thomasville, GA
    5,992
    Here's the correct format for the link.
    I don't know what happened on Bill's post, but the link has extraneous information in it. While this refers to a planer, the same concept can be applied to a drum sander.
    Bill Arnold
    Catalunya
    4,632
    Many thanks to both. Now I understand
    Best regards,
    Toni
    Floydada, Tx
    1,941
    If you are getting snipe, then it should need to releas some of the pressure off the rollers. Check on the end of the rollers for blocks w/ bolts in them. Try backing off the blots a half turn and see if this helps. I know on my Woodmaster if I forget to release the rollers after makeing some moldings I will get nasty snipe.
    Hedgesville,WV
    158
    I don't.. and I can't see how a stationary ext table will work on a moving sanding table.. I could see it on the other DS where the head moves, but on this the feed table moves up/down.....
    Quote Originally Posted by Al killian View Post
    from what I see, there's no adjustment on the rollers... they bolt directly to the frame, and are spring tensioned(think clothes pin type spring action)....
    Feb 2009
    Whittier, CA, USA
    512
    Hello,
    Have you checked to make sure the drive and idle roller at the ends of the table/platen are even with the table/platen? (i.e. remove the conveyor belt and take a straight edge to them.)
    On second thought they might even have to be below the surface of the table/platen, but definitely not above.
    Cheers,
    Dan Gonzales
    Whittier, CA, USA
    Dona nobis pacem
  1. Drum sander
    By Bill McQueen in forum New Tools
    Last Post: 04-22-2012, 04:51 AM
  2. Drum Sander.....?
    Last Post: 10-23-2011, 03:40 PM
  3. Drum Sander
    By Les Hoste in forum New Tools
    Last Post: 01-16-2008, 12:39 PM
  4. Belt Sander vs a Drum (thickness) Sander
    By Ken Close in forum New Tools
    Last Post: 11-26-2007, 01:36 PM
  5. V Drum Sander kit...........??
    Last Post: 04-14-2007, 12:32 AM
