Results 1 to 10 of 12
Thread: Formbys on Shellac??
    Apr 2008
    Butte Montana which is 1/2 way between Purgatory and Heaven
    170
    I want to put Formby's High Gloss Tung Oil ( I know it's not really Tung oil ) on a project made out of juniper. It's a soft wood and has a tendency to "soak up" any finish ie: Poly, Danish Oil, etc.
    So my question is should I use a Shellac as a sealer and if I do would several coats of Formby's adhere to and or build up on top of the Shellac.
    Thank you
    Jiggs Elphison
    Constantine, MI
    7,890
    Use a dewaxed shellac - just about anything will go over it without problems.
    www.wrworkshop.com
    Apr 2008
    170
    [FONT="Comic Sans MS"]Rennie thanks for the response - I am not ashamed to admit my ignorance, but what is the difference between dewaxed and i assume you'll say waxed.
    The only Shellac I've ever used is Zinsser Bulls Eye Shellac.
    Jiggs E[/FONT]lphison
    Dec 2008
    falcon heights, minnesota
    5,610
    zinser's sanding sealer is dewaxed shellac. basically it's had the wax removed.
    benedictione omnes bene
    www.burroviejowoodworking.com
    Odessa, Tx
    1,813
    Quote Originally Posted by Jiggs Elphison View Post
    In the shellac that is used as a "Finish Coat", wax is added in the manufacturing process, to help the Shellac flow out better.
    Shellac used as a sealer OR primer, MUST be DEWAXED, because the wax will keep most other "Finish Coats" from adhering to the Shellac.
    Clear as Mud, huh?
    5,321
    Quote Originally Posted by Norman Hitt View Post
    In the shellac that is used as a "Finish Coat", wax is added in the manufacturing process, to help the Shellac flow out better...
    Not really. The wax is a 'natural' product of the bug secretions that are used to make the shellac.
    If you make your own shellac from flakes, and let it sit for a day or so after mixing, the wax will settle out to the bottom of the container. You can then decant the pure (de-waxed) shellac off the top.
    Zinnzer's regular shellac product is somehow 'homogenized' to keep the wax in suspension.
    Zinnzer's SealCoat® is dewaxed.
    Apr 2008
    170
    Thanks to all that "educated me regarding waxed vrs dewaxed shellac" I'm off to find Zinsser's Seal Coat and start the finishing of my project...
    I'm constantly amazed at the quick response one receives on this Forum
    regardless how elementary the questions are and the answers never contain a hint to the questioner that they should know the answer or that the questioner must be below the the average intelligence level...
    That my friends is a true sign of professionalism and character. I really appreciate and enjoy this Forum. Maybe some day I'll work up enough courage to post some of my efforts to be critiqued. Until than I'll continue to read, inquire and learn.
    Thank you
    Jiggs Elphison
    Thank you
    Jiggs Elphison
    Jiggs,
    Never be afraid to post a question or show some of your work. The purpose of this forum to help us all advance in our chosen hobby/Profession. I am 62 years old and have been doing woodwork for most of my life. First as a hobby and second as a profession. We all can learn from one another. We are all one big happy family.
    5,321
    Jiggs,
    Never be afraid to post a question or show some of your work. The purpose of this forum to help us all advance in our chosen hobby/Profession... We all can learn from one another. We are all one big happy family.
    Very well said, Don!
    Odessa, Tx
    1,813
    You are EXACTLY correct Jim. I KNEW THAT, and have NO idea what I was thinking when I typed that. (Guess I'll have to quit mixing the LOML's computer requests/directives with mine when multitasking). It seems I can't DO three or four things at the same time anymore, (at least Not Correctly).
    Thanks for correcting my Blunder. (I have now removed the "blunder" in that post to prevent confusion to others.
  1. shellac
    By Rex Bloem in forum Finishing School
    Last Post: 03-17-2011, 03:12 AM
  2. shellac problems
    Last Post: 07-30-2010, 02:16 PM
  3. Shellac on Mesquite
    By Dan Mosley in forum Lathe Project Showcase
    Last Post: 02-25-2010, 04:49 AM
  4. Shellac flakes
    By Bartee Lamar in forum Finishing School
    Last Post: 09-19-2009, 06:31 PM
  5. What's up with my shellac?
    By M Toupin in forum Finishing School
    Last Post: 07-28-2007, 04:21 AM
