Results 1 to 6 of 6
Thread: About variable speed motors
    3,134
    I have read somewhere that it may be possible to use a motor out of a treadmill to power a lathe but don't remember where I read it is this really possible? I see treadmills from time to time on freecycle. There is one there now.
    First of all tread mill motors are geared down so that the person using the tread mill can keep up with the belt. Second They are fractional hp motors so they don't have the power without the gearing to do much good. If it were a very small lathe maybe but I personaly don't think it would do very good.
    Inside the Beltway
    2,666
    Bart,
    I've heard of a lot of people doing this. I think most of them pair the motor with some kind of control to take advantage of the variable speed options. If you can get one on freecycle, it's probably worth a try.
    Bill
    5,319
    Don,
    The motor on mine is 1¼ hp, and the gearing is external.
    The main problem, as I see it, is adapting the electronics from the treadmill control panel to a smaller controller box for the lathe.
    Southeast Pa
    2,019
    Well most treadmill motors are DC and rated around 2 HP. This is very likely very small horses but they are way more than fractional horse power.
    There has been a lot of information on the metalworking lathe groups about using these.
    I have two sitting in my basement now waiting for time to put on my mill and drill press.
    Also 3 phase solid state drives for 3 phase motors are becoming quite affordable in the 2 hp and under range. They are probably a better way to go even if a bit pricer.
    Garry
    Honolulu, Hawaii
    1,103
    Bart,
    Jim and Gary are correct.
    The DC motors will work nicely and those are "Traction motors" so their torque is fairly constant throughout the speed ranges. If the treadmill controller won't work, or is too hard to minimize in physical size, there are aftermarket controllers that are reasonable.
    As for the 3 phase motors, some VFD's are not that expensive and will give good control of a 3 ph treadmill motor.
    Either choice will give you good power and nice usable speed ranges. I have one of each just waiting to be used on one of my lathes.
    Aloha, Tony
    Ah,,,to live in Paradise!
    Registered voting member
  1. Variable Speed on Lathe
    By Rich Aldrich in forum Turning Tool Questions and Show & Tell
    Last Post: 09-25-2009, 10:55 PM
  2. 1HP variable speed lathe for less than $400??
    By Jeff Bower in forum General Woodturning Q&A
    Last Post: 05-21-2009, 08:58 PM
  3. major confusion on variable speed thingys
    Last Post: 06-16-2007, 04:16 PM
  4. Belts vs Variable speed
    By Tony Falotico in forum Turning Tool Questions and Show & Tell
    Last Post: 05-30-2007, 04:39 PM
  5. Variable Speed-Induction Motor
    By Russell Svenningsen in forum General Woodworking Q&A
    Last Post: 02-20-2007, 12:13 AM
