Gave you my thumbs up Mike but I am stuck for words. You certainly are an inspiration to have around here.
Larry you sure are astute to spot the dovetails. I am still getting there. But Mike your explanation I understood cause i built a draw back at high school and wondered why we put the groove for the bottom so far from the bottom. Today i got the answer. Dont think the teacher even knew at the time.
Where is that piece going to end up Mike? Is this a piece you intend to use at home or is it a commission for someone.? Those carvings are unreal.
Best of luck in the contest.
Oh Mike went back for another look see andit made me think (duh) those draw fronts I guess the piece that you cut them from was around 2.5 inches thick or are there two layers?
