Results 1 to 10 of 14
Thread: Belt Sander or Orbital Sander
    Hi, I am looking for a good all around sander. I don't do a lot of sanding, but from time to time I make a small coffee table or glue up a few boards and need to sand.
    Whats a more all-around, practical, and useful sander ... orbital or belt?
    Thomasville, GA
    5,994
    If you're only going to have one sander, make it an ROS (random orbital sander). You can take off a lot of material with low-grit disks and go all the way to pre-finish sanding with an ROS. It also leaves little, if any, sanding marks when used properly.
    Bill Arnold
    Bill is absoloutly correct. My belt sander is only used when I want to get real aggresive. My ROS is my goto tool and I have every grit paper I can get for it. I also have a finish sander but if your only going to have 1 the the ROS is the way to go.
    Ditto
    +1 on a ROS. I can't tell you the last time I used my very nice belt sander.
    17,472
    another vote for the orbital and there are uses for a belt but nearly as many..
    5,321
    Festool Rotax - either the 5" or the 6" model. Expensive, but worth it. In Rotax mode, it removes stock almost as fast as a belt sander, but in ROS mode, it's a great finish sander.
    Constantine, MI
    7,890
    Another vote for the ROS
    www.wrworkshop.com
    Villa Park, CA
    1,407
    I have both and I can't remember when I last used my belt sander.
    Mike
    Ancora imparo
    10,604
    ROS for sure. I've only used my belt sander 2 or 3 times in a couple of years. The Porter Cable that I have has been working great for 3 or 4 years.
  1. Best Orbital Sander under $100
    By Jeff Bower in forum New Tools
    Last Post: 12-02-2015, 02:23 PM
  2. Porter cable orbital sander caught fire
    By Jake Vrbka in forum New Tools
    Last Post: 04-10-2012, 01:01 AM
  3. Replies: 0
    Last Post: 03-06-2012, 01:35 PM
  4. Rigid Osc Belt Sander
    Last Post: 09-28-2008, 07:31 PM
  5. Belt Sander vs a Drum (thickness) Sander
    By Ken Close in forum New Tools
    Last Post: 11-26-2007, 01:36 PM
