Results 1 to 3 of 3
Thread: Book shelf
    Sep 2007
    Bloomington MN USA
    268
    Book shelf
    I am starting to build a book case for a customer. They want it painted,so am useing pine and a hardwood plywood. It is not plys under the venier...it's solid wood. Have not used this type befor but thought it would be good for the sides of the case and also the shelves. Have any of you used this type of sheet stock before? Pros and Cons of it would be helpfull.
    If you make a mistake it was part of the original plan!
    17,475
    i believe thats called lumber core and i havnt seen any in many years where did yu come by it ron? it should be excellent stuff
    Sep 2007
    Bloomington MN USA
    268
    Larry, I found it at HD $45.00 per sheet. I was hoping with the fact that they wanted it painted, I may get by without banding the shelf edges? Have not used it before. Hoping there will be no voids. We will soon find out after cutting into it. Thanks for the info.
  1. A Shelf for George
    Last Post: 08-16-2015, 06:19 AM
  2. Book Shelf Project for Moi! Update
    By Carol Reed in forum Flatwork Project Showcase
    Last Post: 03-27-2012, 05:11 AM
  3. The Shelf
    By Bill Satko in forum Handtool Project Showcase
    Last Post: 01-16-2012, 02:27 AM
  4. shelf supports
    Last Post: 03-19-2011, 06:06 PM
  5. Shelf pin jig?
    By Al killian in forum Jigs and Fixtures
    Last Post: 08-10-2009, 11:45 PM
