Page 1 of 4 1234 LastLast
Results 1 to 10 of 39
Thread: Not Just A Fishtank Stand
    London, Ontario
    3,383
    (haven't done an "in-progress" project thread in a while...)
    I finally got some of my other round-tuits/honey-do's out of the way, so it was time to tackle the fishtank stand/cabinet that I'd started planning a while back. The design and background was posted over in the design sub-forum back in July and following.
    This project is mostly a big cabinet, made with lots of sheet goods. But still, I'm pretty happy with the design, and I take plenty of pleasure in putting together a well designed piece of functional furniture.
    I started on some of the parts last week... The carcass is from a sheet of 3/4" maple plywood. (This was the piece where I put the edge tape on the wrong sides)
    There is a small toe-kick out of the lower-front corner. This is not 'regulation' kitchen cabinet size. I'm trying to maximize the cabinet volume. (greedy, I know) But we still want a toe-kick, mostly so we can slip our foot under the left-side drawer (where the trash can/recylcing bin will sit) and use it to pull it open. We do that on our under-sink cabinets now, and it is very handy -- and that is an understatement.
    Some of the cross-members and other bits:
    Today I put it all together -- at least all the bits I've built so far.
    Here was another learning experience... Having just a single center divider can be a problem when you're building with pocket hole joinery. I didn't even think about this until I was getting ready to put it together. That was when I realized that anywhere that I had two cross-members touching the center divider at the same place, I was probably going to have trouble with the pocket screws hitting each other.
    I was able to avoid that in a few hidden places by alternating the orientation of the cross-members. Some had the screws angled up, some angled down. But I still had a couple places where it just didn't work and I had to macgyver a solution. Oh well, once it's built no one but me will ever know about it. But I confess here, in the hopes that others will learn from my oops. (Though I'm more concerned that *I* learn from this...)
    The top is loose right now, not going to be attached until the end. The carcass is getting a blue stain. And the top is just going to get a bit of shellac, to warm up the pale maple, and then the whole project will get a whole bunch of varathane topcoats --- remember; fishtank. (I bought myself an Earlex in the summer, and this will be my first chance to give it a shot.)
    And yes, there is a hole in the back. (which is 1/4" BB by the way).
    The top right drawer is going to be about 4" shorter than the others, from front to back. This is to give me room back there to hide a power bar for the various A/C adaptors and plugs as well as a room for one or two air pumps for the tank.
    Next up will be drawer construction. And I haven't even started milling the maple that will make up the drawer fronts. But it's got to be done by Oct 16 (LOML's bday party) so I'm under the gun, a bit.
    ...art
    North West Indiana
    6,097
    HOLY COW!!
    Got my attention!
    Keep us posted!!
    Or we will need to !!!!
    Jon
    13,437
    Coming along nicely Art! Are you building a matching hood? or just using the factory hood?
    10,600
    Looking real good. I gotta remember the pocket screw lesson.
    12,247
    Hi Art the fishtank stand is looking good. Just out of curiosity is there any particular reason you did not use a face frame on the front.?
    I would have thought that with the weight of the fishtank on top that the faceframe concept would have given added structural strength to the plywood and hidden the front so as not to require the banding. Also providing place for the draw glides to be mounted and hidden.
    Not trying to be smart here just wanting to understand pros and cons given whats going to go on top?
    London, Ontario
    3,383
    Factory. I've only seen a few stands with wooden hoods, and only in the last few months. So I've never really considered it. It does seem to me to be one place where plastic/glass makes more sense than wood. And I just like this look.
    Rob, I did address the weight issue in the design thread: "After looking back at the original stand that came with the tank I realized that they just had some 5/8" particle board for the top, and a simple box for the base. So what was I worried about?"
    If you take a second look in that thread at thephoto of the ugly black stand that came with the tank, you'll see that not only was it a basic box, but it had a big door in it, and you can't see the big hole in the back of it also (for hoses, etc). So the weight of that was mostly born by the two 5/8" melamine sides.
    My design has Three 3/4" plywood supports, not to mention the (nearly) full back of 1/4" BB. I have no concerns at all about this being able to support the weight.
    The face frame question is a valid one. I considered a face frame, but decided that the frameless Euro-Kitchen style of cabinets would both be quicker, simpler, and suit the kitchen environment where it is going to stand. (I was going to say that it also matches our current cupboards, but as those are butt-ugly and due to be replaced when the kids are older, they don't really bear mentioning.)
    thanks for the comments!
    Aug 2008
    NorCal, USA
    495
    Freshwater tank?
    new york city burbs
    10,188
    are you putting in drawer slides?
    just wondering if you were how come ya didnt put them in before you assembled the cabinet.
    London, Ontario
    3,383
    Quote Originally Posted by Chuck Rodekohr View Post
    Freshwater tank?
    Yup.
    cuz this is the first time I've ever heard of such a technique...
    Have I been hiding under a rock? Seriously, I've never even thought of doing that!
    new york city burbs
    10,188
    I did not mean to offend or insult you.
    Ive found that now that I started putting drawers in things(I never had luck so I didnt put drawers,only doors with open cabinet space and shelves), its 5 times easier for me to line up drawer slides and put them in absolutley straight without having to work in the confines of a cabinet, with dividing walls and other attachments in my way.
  1. Fishtank Stand - Evolution + Planning
    By Art Mulder in forum Designs, Plans and Sketches
    Last Post: 09-08-2009, 02:23 AM
  2. TV stand
    By Al killian in forum Flatwork Project Showcase
    Last Post: 08-06-2009, 01:00 PM
  3. T.V. stand
    By Al killian in forum Designs, Plans and Sketches
    Last Post: 05-26-2009, 10:19 PM
  4. TV stand
    By Dan Birnbaum in forum Flatwork Project Showcase
    Last Post: 03-23-2008, 09:11 PM
  5. TV Stand
    By Ed Nelson in forum General Woodworking Q&A
    Last Post: 01-22-2008, 01:39 AM
