Results 1 to 10 of 10
Thread: How to Finish Cabinets?
    Palm Springs, Ca
    1,169
    I was wondering what can be done with slightly faded and worn looking cabinets ? They were custom made along time back and when i asked about refacing them i was told that it would be to costly and so would be installing new cabinets. The suggestion from the one contractor would be to refinish them myself. I just dont see myself wanting to try to sand down all those cabinets and doors so i thought i would see if anyone has any suggestions on going over the existing finish ?
    Thanks Dan
    Attached Thumbnails Attached Thumbnails Counter-1.jpg   Counter-2.jpg   Counter-3.jpg   Counter-4.jpg
    Dec 2008
    falcon heights, minnesota
    5,610
    acetone would probably take that varnish right off.
    benedictione omnes bene
    www.burroviejowoodworking.com
    For stripping I use a product I get from True Value called Daqd's Spray stripper. It's got a fair amount of Metholyne Chloride in it. Put down plastic and spray it one let it siet a few secodns and scrape away the old finish. Sand to 220 and finish. Wear rubber gloves.
    Apr 2009
    Outside the beltway
    5,260
    Looks like good solid maple cabinets. Like Don said spray stripper then denature alcohol with scrubby pad to remove the stripper after you use the broad knife to remove the stripped finish. The denature alcohol will rinse the doors good and not raise the grain. Plus quicken the drying time. Then sand with 220 seal 3 coats and then 320 and finish. Maple cabinets look great natural.
    Palm Springs, Ca
    1,169
    I am going to do them as suggested - Thank you Dan
    12,260
    Thank you Dan for bring up the subject. Don and Dave boy you guys know your stuff and are a wealth of information. Glad you guys are around and on our side. I have always been concerned about how to go about stripping, Have an old ball and claw drop side table from my Mom that i would like to clean up with new coat. Now i know how. Dave on the denatured stuff can i use something else. Here in Canada the Feds think we will drink grain spirit even if its got some poison in it so its hard to come by. I can get the methylhydrate stuff but that is petrolium based not grain alcohol.?
    Rob, with metholyne chloride you can use water to rinse it off but you may need to use a second coat.
    I use water all the time, I take the piece out side and hose it off. I use a scraper and a stiff brush b4 I hose it off. Or you could just use some cheap vodka..
    Apr 2009
    Outside the beltway
    5,260
    Acetone is a good product to strip with , but it evaporates so fast you work one area about 1'x1' at a time with a purple stripey pad. I will use acetone for large conference tables that will not fit in the stripier tank. It also is great for the fact that no grain will rise on the wood.
    Palm Springs, Ca
    1,169
    both are great ideas and im going to try it soon.......
    Apr 2009
    Outside the beltway
    5,260
    Dan , do you have any work done on the cabinets yet. With all that great weather you guy in Ca get you should be done by now.
  1. Arcade Cabinets
    By Darren Wright in forum Designs, Plans and Sketches
    Last Post: 11-11-2017, 01:26 AM
  2. Mappa burl cabinets....Phase II update cabinets installed
    By Alan Bienlein in forum Flatwork Project Showcase
    Last Post: 05-23-2009, 06:15 PM
  3. Cabinets and SU
    By Gregory Hairston in forum Designs, Plans and Sketches
    Last Post: 12-09-2008, 12:28 AM
  4. Replies: 1
  5. We have CABINETS!
    By Don Taylor in forum General Woodworking Q&A
    Last Post: 11-26-2007, 11:44 PM
