Results 1 to 10 of 10
Thread: wassup with 51 degrees?
    11,832
    I just received an e-mail from Skil that is promoting a new circular saw that cuts at a 51 degree angle.
    I guess that is nice. But, what is a cut like that used for?
    http://www.skiltools.com/en/AllTools...?pid=HD5687-01
    17,472
    they match it up with a 39 degree one that the guy before yu had cut and thought was a 45 to get a squaer corner Frank.
    11,832
    Huh? Knowin' ye, Larry, I dunno ifn' thet's pullin' my leg or fer real.
    Somebody rescue me, please.
    Villa Park, CA
    1,407
    Sometimes you need a cut more than 45*, maybe because the corner is not square. I doubt if you ever need to go to 51* but I suppose they went far enough to make sure you had enough. About the most I've ever used is maybe 47* or 48*.
    You can't really match up two different angles in a corner. So you can't really do one side at 39* and the other at 51*. The length of the two cuts won't match - the length of the angle part of the 51* cut will be longer than the length of the 39* angle and when you put them together they'll look terrible. When doing a miter cut, you have to divide the angle in two to get a good fit. So if your corner was 94*, you really have to make two 47* cuts to get them to fit together properly.
    I'm sure Larry knows that and was just pulling your leg.
    Mike
    Ancora imparo
    I imagine it is like the stops on my machines. I generally set them a bit past zero and 45* for example; that way I can be precise as opposed to trusting the not-so-trustworthy stops. The 51* would allow you to easily do more that 45*, whatever it happened to be (up to 51* of course).
    Odessa, Tx
    1,813
    Well, it depends on whether it is a Skil Pro model, OR whether it's a model sold at the Borgs, ie; If a Pro model it was probably planned to give plenty of leeway to set something more than 45* when needed, Buuuuuuuut.... IF it was a model made for the Borgs, it was probably planned to be 48* like most of the competition, but the machining was a little "sloppy" and ended up being 51* and rather than redo all the parts they just decided to ADVERTISE 51* as a FEATURE.
    10,604
    I don't have any clue. I would guess the guys who say better miter accuracy are on target but I sure don't have the skill to cut super accurate miters on a circular saw.
    I'd use my sliding compound saw to do it.
    3,132
    Frank i don't know anything about the skil, but my new makita will cut up to a 56 degree. Yes i have used degrees over a 45 many times. Say you are putting up a rim board for your I joist to butt into. With the funkie angles the architects are putting in these big houses it's prutty common.
    Heres a pic of my new saw and as (i hope ) you can see it does go up to the 56 degree. and yes it will cut all the way through a 2x4.
    new york city burbs
    10,188
    they get to charge more for the bigger angle.
    3,132
    Allen I only payed 135.00 for my saw. The last one i bought over 10 years ago i think i payed around 120.00 so i think that was more than fair. Not sure if the borgs sell it for the same price as i got mine at williams supply and rental.
  1. Gonna be cold tommarrow, weatherman says 25 degrees
    Last Post: 01-22-2014, 12:45 AM
  2. 20 degrees in the shop
    Last Post: 01-08-2013, 02:29 AM
  3. OMG it's 70 degrees outside
    By Tom Baugues in forum Off Topic Discussion
    Last Post: 03-14-2012, 02:56 PM
  4. It's going on to 8 PM and it 90+ degrees
    By Don Baer in forum Flatwork Project Showcase
    Last Post: 06-13-2011, 06:55 AM
  5. 15 degrees, 15 minute project, clock
    Last Post: 01-06-2010, 10:52 PM
