Results 1 to 10 of 14
Thread: seeking name of joint
    In all my years of schooling, teaching, shopping and now Internetting I have not run across the "Name" of this joint, although I have several antique chests and dressers with the drawers joined this way. All I have ever heard was "Drawer joint" or "Round peg joint"... Just bothersome that I like to have a name and some closure before my dimentia overwhelms my anal concerns.
    Any of you brillant WWing Scolars have the answer, for I am discovering that I really don't know it all
    Sacramento, CA
    1,367
    The small bit of searching I've done says that's called a Knapp Joint
    http://www.worthpoint.com/editorial/...-check-joinery
    Or so the internet tells me
    Jason Beam
    Sacramento, CA
    Bellingham
    2,449
    Good job Jason! Using your lead I found out it was also called the pin and crescent joint. << Link >>
    17,474
    thanks jason, i had seen them many times and hadnt seen a article on them..glad yu showed us what it was..is there any chance that they had variations of it.. i have got a piece of drawer that has lack of better terms got bears ear shaped sides that fit in like the knapp does but no pins like the knapp? dont meant to hyjack, mr Simpson but yu got your answer above and fast
    Sacramento, CA
    1,367
    Larry,
    Leigh makes a jig (I think) and I know Woodline does as well that lets you cut all kinds of quirky shapes like bear ears and heart-shaped pins (called Lovetails, cute eh?). For example:
    http://toolmonger.com/2008/02/15/dre...isoloc-joints/
    or
    http://www.woodline.com/p-1825-route...ry-system.aspx
    Maybe those are similar to what you have?
    Jason Beam
    Sacramento, CA
    17,474
    jason this was made before those companies existed willget it out and take pic sometime and post it so you can show me what it is like yu did Mr Simpson.
    I looked up the Knapp joint and found considerable info on it. Should have been easy to find but I was stumbling over my ignorance. thanks for leading me from the pit of dumbness.
    Although I don't have a Knapp Dovetail machine from the Knapp dovetail company I would like to use that joint in a future piece, Looks like it would be a royal pain w/o the machine. but a reproduction could be nice.
    I have often made drawer joints using a rabbit and dowels.
    Thanks for enlightening my small brain
    PS... whats with the MR stuff
    Catalunya
    4,632
    Great info guys! I've bookmarked this thread for future reference. Thanks.
    As I could not get away just like that, check this link as well, these are hand made but also attractive.
    http://www.amgron.clara.net/dovetail...orishindex.htm
    Best regards,
    Toni
    I make my lovetails by hand, but they are a little different then what the link is showing, because the ones I make are done with the hearts facing right side up when you view them from the side of a drawer. You also have to plan the ones I make a bit as they can only work on a drawer one way due to the pulling effect.
    The interesting thing is, I learned to make lovetails long before I could make dovetails. I am not sure which is easier to make though, both have their strong and weak points. The hardest part about making them is getting the layout right, and as you can see in the picture, I messed up on these as the hearts are not spaced perfectly in the height of the drawer. (my bad I know). Its tough because the perfect heart shape is 2/3 longer then it is wide, so the center of the heart is kind of deceiving to find when you got a row of them.
    Here is a picture of some lovetails that I made on my daughters train-shaped cradle. I used the lovetails in the drawers underneath the locomotive cab. As a side note, it looks like the hearts are merely painted on, but what you are seeing is the end grain forming the hearts and they are darker because it sucked up the stain from being end grain wood. These are chiseled out of the solid wood that forms the front of the drawer. The sides of the drawer is a heart shaped socket. Glue keeps everything together, but as you can see the drawer has to be made this way, that way as you pull on the handle, the heart shaped pins pull against the sockets on the side boards of the drawer. If the hearts were the other way, you would only be relying on glue to keep them together.
    Oh what the hay, I am on a roll here so I'll continue with my little theme here on unique dovetails. This was a hanging gun cabinet I made for a guy with the case put together via Pistoltails". That is the pins and sockets were made in the shape of pistols. The chiseling of the pins was time consuming, but it made for a unique joint holding everything together.
    There was one point that should be made on this. In the interest of promoting gun safety, where a gun should never be pointed at anyone, I had to make two versions of the pistoltails...one facing right handed and one facing left handed. In that way when viewed from the sides, the pistolstails face the wall. If I used the same pattern, the ones on the right would face the wall, and the ones on the left would face the interior of the room. A small detail perhaps, but one I was compelled to do.
  1. Be careful what you wish for! Seeking advice.
    By Randal Stevenson in forum General Woodturning Q&A
    Last Post: 07-13-2014, 02:11 AM
  2. Seeking guidance from the collective
    By Rennie Heuer in forum Carpentry and Construction
    Last Post: 05-23-2010, 07:38 PM
  3. seeking rail & stile bit set
    By Bill Simpson in forum General Woodworking Q&A
    Last Post: 04-27-2009, 08:51 PM
  4. Seeking more planer input
    By Tony Maio in forum General Woodworking Q&A
    Last Post: 03-13-2009, 12:34 AM
  5. Seeking Radio headphones
    By David Trompower in forum General Woodworking Q&A
    Last Post: 12-09-2008, 05:28 PM
