Results 1 to 10 of 15
Thread: Getting started turning
    Central PA
    638
    I have a jet 1236 lathe that I got about 12 years ago. I haven't used it too much and I decided to start to make some bowls and sell to get money to buy a sawstop PCS. I have a CHEAP set of chisels that came with the lathe. I want to start getting some better tools for the lathe but I can't spend much or that kinda defeats the point of making money for the sawstop. I was thinking about getting a nicer gouge and some sort of jaw chuck to start with. In the past when I have done some bowls, ( like 2 bowls) I just used the faceplate with screws but I wasn't a big fan of that method. Maybe that is the best method, I don't know. I saw Mark Cothren's thread http://familywoodworking.org/forums/...ad.php?t=13180
    and saw that he was using a jaw chuck to hold the bowl. I was looking at the chucks from grizzly and was thinking about getting one from there. Any thoughts where so start?
    Palm Springs, Ca
    1,169
    Thompson Tools - Sells some very nice tools and if your only looking for gouge to start you will not go wrong with one of his tools. If your going to spend the money for a good gouge you might check out his line of lathe tools. Randy is also a memeber here on the site and easy to talk to if you have questions.
    3,134
    I've seen posts recommending the Barracuda chucks.
    http://woodturning.pennstateind.com/...Chuck&x=14&y=6
    Goodland, Kansas
    4,834
    I have 3 of the $99 grizzly chucks (yea I know I am lazy and don't like changing jaws) but the Vicmarc VM 100 jaws will fit the grizzly chuck. I also have the Vic VM 100 and it is a excellent chuck but pricey. They are a great chuck for the money.
    Bernie W.
    Nov 2008
    Tampa & NC
    432
    I'll second Dougs tools.I have several of them,just ordered a 3/4 skew from him.A good thing about Doug is that if you call or email him,he will be more than happy to help you pick out the tool best suited for you turning needs.He's a great guy to deal with.
    Central PA
    638
    I was looking at the $42.50 grizzly 4 jaw chuck, any thoughts on that one? If that is not a good one I could probably get the $99 chuck but right now I would like to keep costs down. Is the 4 jaw chuck the best way to turn bowls? Thanks for the info on the gouges, I will take a look at them. I have done a few very simple bowls on the faceplate but thats it. Any info on bowl turning would be appreciated. Thanks
    Tellico Plains, Tennessee
    4,352
    Dave,
    I use both the face plate and the chucks... I like to start the bowl on the face plate until I get the tenon cut on the bottom for the chuck. I've tried just using a drive spur, but I don't think it's as effecient as the face plate... that's just my opinions and my way of doing.
    I use the PSI 4 jaw Barracuda chucks.. I have 2, plus a smaller one I forget the model of right now... all are PSI chucks though... If you are doing larger bowls, you might look at a larger chuck, but I've turned up to a 12 inch bowl on the ones I have. The only thing I don't like about them, they use tommy bars to tighten, I would really like to have a single key.. sometimes I need 3 hands to get a piece on the chuck.
    I don't have really good tools, most of mine came with my original lathe which was a Ridgid from Home Depot.. another set I got when my son gave up his lathe, a Jet 1014 and a set of tools... plus I bought a few cheapies from harbor freight that I played with for sharpening, etc... my bowl gouges are Benjamine best from PSI, they're about $50 for the set of 3...
    Chuck
    Tellico Plains, TN
    Goodland, Kansas
    4,834
    Quote Originally Posted by Dave Black View Post
    Dave I also have the $42.50 chuck. It was the first one I bought and haven't been sorry. It uses tommy bars but like I said it works just fine for the money for me was good buy.
    Bernie W.
    Goodland, Kansas
    4,834
    Dave I also have the $42.50 chuck. It was the first one I bought and haven't been sorry. It uses tommy bars but like I said it works just fine for the money and for me was good buy.
    Bernie W.
    Central PA
    638
    I am going to be stopping at woodcraft tomorrow and saw that they have a woodriver 4 jaw chuck for $86.50. Would this be a better option than the Grizzly $42.50? Anybody have the woodriver chuck?
  1. Just getting started
    By Chuck Thoits in forum Carpentry and Construction
    Last Post: 04-15-2012, 06:09 PM
  2. Well, it started out flat!
    By Russ Wood in forum Flatwork Project Showcase
    Last Post: 01-19-2012, 12:24 AM
  3. Started a new one
    Last Post: 02-17-2010, 04:00 PM
  4. Started moving in...
    By Kirk Constable in forum Shop Tours
    Last Post: 04-08-2009, 05:46 PM
  5. FINALLY !! i can get started turning
    By Joan Keeler in forum Turning Tool Questions and Show & Tell
    Last Post: 10-07-2007, 09:19 PM
