Results 1 to 10 of 10
Thread: any painters
    Winchester Ky.
    98
    any painters
    I am looking to buy a a small gravity spray gun to paint small thin wood frames. I want small spray patten 3 to 4 inch at low air volume. Little over spray. Do any of you have any experience and advice on a gun and type of paint that has worked for you. I just starting this process and any advice would be appreciated. It would probably help save me time any money trying to figure out the best method by experimenting on my own. I am looking for a smooth finish for picture frames and small furniture projects. I am having trouble on trying to decide to use oil base, water or lacquer. Thanks for any advice you can offer.
    Ken,
    I have two the regular size one and a one. Both are from Harbor frtght. The both work well.
    ken,
    here`s a link to the touch-up gun i use.
    http://www.spraygunworld.com/product...%20SHP7040.htm
    5,322
    I use a little Harbor Freight 5.5oz HVLP touch-up gun for spraying shellac and clear lacquer. Works pretty well. Costs around thirty bucks.
    I haven't used it with paint, but I've had good results shooting waterbased clear (and alcohol-based dye) with this gun:
    http://www.spraygunworld.com/product...exMiniGun.html
    I've also read a lot of good comments about the Harbor Freight mini HVLP guns, and of course, you can't go wrong with the Sharpe gun that Tod pointed out.
    Winchester Ky.
    98
    Vaughn and Tod how small of pattern can you spray with the guns that you listed?
    You can make it a very narrow pattern, never checked to see how small but it's pretty small.
    Ken, I've not really checked for specific widths, but if you're holding the gun close to the item being sprayed, 1" or narrower should be pretty easy as long as things are adjusted right for a light spray.
    Quote Originally Posted by ken lutes View Post
    3/4" or so....the gun i use sprays a round pattern not a fan.
    Winchester Ky.
    98
    re
    Ok thanks guys.
  1. Are there any house painters....in the house?
    By Greg Cook in forum Carpentry and Construction
    Last Post: 09-17-2007, 10:02 PM
