Results 1 to 9 of 9
Thread: Belt Sander - Sanding Shoe Question
    Palm Springs, Ca
    1,167
    Has or is anyone on here using the sanding shoe that goes on a belt sander? I have a Makita Belt Sander 9903 3 x21 and i was told that the sanding shoe will make the belt sander act like a drum sander by making the sanding level across a large flat surface.............anybody have any thoughts here?
    Is there a website where it describes the sanding shoe ? I am unabe thru a search to come up with anything describing its use etc....
    Thanks Dan
    Honolulu, Hawaii
    1,103
    Dan,
    I think you need to get more info on this, because almost all belt sanders I have seen and used have a replaceable wear shoe. I replaced my Portet-Cable shoe when it got bad. Same size as your Makita, 3"x21". There was a cork cushion glued on the shoe that goes between the sander body and the shoe that seems to get compressed from use. The metal wear plate was still pretty good though.
    I really don't know how you could make a belt sander into a drum sander unless you only sanded with one end roller. Maybe that's how? Be interested to learn how.
    Aloha, Tony
    Ah,,,to live in Paradise!
    Registered voting member
    30,008
    Tony, I've seen pictures of a contraption that goes on the outside of the sander, sort of like a flat front, rear and side outrigger. It's set just a hair off flush with the sanding platen, so that the sander can't rock or dig in to the workpiece. I think they are more common in Europe than here in the US, but hopefully someone can post a link to a picture.
    Honolulu, Hawaii
    1,103
    Yeah, that sounds like something to look at. Hope someone knows where that info is. Thanks Vaughn.
    Aloha, Tony
    Palm Springs, Ca
    1,167
    Vaughn - Tony
    My understanding of how it works is like Vaughn was saying and i was thinking that on large slabs of wood it would be possible to sand level and avoid having to find someone with a large drum sander and pay the high shop rates but i cant find enough info on it. Ill try to call Makita tomm and let you know more details.....below is a link but it does not say much
    Makita 1930707 SANDING SHOE, 9903 - Makita Tools
    http://www.acetoolonline.com/Product...te=google_base
    Dec 2008
    Portland, Oregon
    1,898
    Not sure, is this what you're talking about??
    link
    Jesus was a Woodworker
    Also known as a sander frame:
    http://www.finehomebuilding.com/how-...der-frame.aspx
    I had a friend that used his extensively for table tops etc. He loved it.
    Wes
    A good sharp Jack plane will do the same think with less effort and not require the use of a ROS.
    Palm Springs, Ca
    1,167
    I called Makita today and spoke with someone in technical service about the sanding shoe. They do not any longer make it and the reason was they were not selling enough units and then it became a pricing issue.
    I was told that most user do not keep the beltsander perfectly flat and something they will dig in on the edges while sanding and not even realize there doing it so with the shoe in place this will not happen and your sanding will be perfectly flat - you can also adjust the depth of the cutting from the belt to the shoe and take off only so much at at time but you still have to keep it constantly moving.
    I assume that from the above you will still need a straight edge to check your leveling as you go and change from grit to grit to ensure you are keeping your surface level.
    I agree with the jack plane but im not any good at it to tell the truth and i have a belt sander and for projects here and there i thought this may be a good solution.
    Thanks Dan
  1. Sanding Belt for Sharpening Knives
    Last Post: 07-05-2014, 09:00 AM
  2. Belt Sander or Orbital Sander
    By Dawson Mossman in forum New Tools
    Last Post: 09-18-2009, 01:03 AM
  3. Belt sanding with/without dust extraction.
    By Uys van Rooyen in forum Off Topic Discussion
    Last Post: 02-24-2009, 04:06 PM
  4. sanding belts or belt sander
    By Chuck Beland in forum New Tools
    Last Post: 06-21-2008, 10:37 PM
  5. Belt Sander vs a Drum (thickness) Sander
    By Ken Close in forum New Tools
    Last Post: 11-26-2007, 01:36 PM
