Results 1 to 6 of 6
Thread: Round Peg in a Square Post
    Toronto, Canada
    276
    A couple of questions were asked in this thread, in Handtool Haven, about a steadyrest I'd posted. Hopefully the pictures will speak for themselves. If not, ask away.
    Layout for the square hole was done with the toolrest (indexed)
    Sorry, no pic of the 1x8" dowel, but it's in there and the sections line up.
    11,828
    That's a honkin' big lathe.
    And, I have never seen a grinder mounted like that one high on the wall.
    Cornwall, England
    392
    Do you turn telephone posts on that thing? Also is it backward or do you turn from between it and the wall? Makes my little lathe look like a miniature instead of just a mini.
    Pete
    30,008
    Very slick, Ed. I'm still trying to decide if you were thinking outside the box or within the circle, but either way, I'll have to remember the concept in the event I run into a problem it could solve.
    Toronto, Canada
    276
    Looks higher than it is, Frank. The arbor is at eye level, and with the jig arm rotated down , the bowl gouge handle is out of the way when in grinding. Both grinders and the sander hang on french cleats, and can be moved as necessary.
    Quote Originally Posted by Pete MoncrieffJury View Post
    I built it to turn bo (6' fighting staff) for karate. Normal use is with back to the wall but, it has a sliding/rotating head so it can be set up to turn from either side.
    Los Angeles, CA
    2,668
    Thanks Ed.
  1. Round Mortise with Square Tenon?
    By Bob Beasley in forum General Woodworking Q&A
    Last Post: 10-01-2015, 02:59 PM
  2. How NOT to make square wood round
    Last Post: 05-09-2013, 07:14 PM
  3. Square and Round too......
    Last Post: 02-24-2010, 02:15 AM
  4. How does that square peg in a round hole thing work again?
    By Jesse Cloud in forum General Woodworking Q&A
    Last Post: 03-18-2007, 03:38 AM
  5. Converting square to round-An adventure in DC exhaust.
    By Jim O'Dell in forum General Woodworking Q&A
    Last Post: 11-13-2006, 11:51 AM
