Results 1 to 10 of 16
Thread: Zircon And Other Stud Finders
    Eastern Panhandle of West Virginia
    103
    Question Zircon And Other Stud Finders
    .... After reading this thread http://familywoodworking.org/forums/showthread.php?t=1466
    I felt I should share this post with everyone.
    .... I wanted to put up some shelving on a given wall the other night. Over an hour later, I hadn't got past trying to find two of four studs in the wall. The bottom half of the wall is particleboard and the top half is sheet rock. I finally established a ROUGH line on one side of one of the studs. On the other side of the stud I could NOT establish consistent repeatable mark(s). Matter of fact, I now have a whole wall full of marks that I cannot draw a straight, vertical line down on the other side of this stud. I have two Zircon units that I was using and replaced the batteries in both (Studsensor 4 and the Triscanner). The Studsensor 4, which I think is slightly more sensitive than the Triscanner, have some differences between them. For the most part I could NOT establish a good repeatable mark(s), some would be 1/4 to 1/2 from the first original mark and some did repeat but NOT enough to feel confident enough about to draw a second straight vertical line on the other side of this stud. I did try using a piece of paper under the scanner and that did help in a smother operation, especially on the particleboard, but didn't seem to help with repeatability. I talked with the manufacturer ZIRCON and the bottom line there was to try a thicker slide like the backing of a (pad of paper [the cardboard]) which is a little thicker than what I used (piece of paper) and I will try that. The question that begs an answer now is - Is there anyone who has had the same experiences or frustration that I now share?
    Thanks in advance
    Boyd
    .... Update: I also recently purchased the STANLEY IntelliSensor and though I did not go to the same extent in comparing I got the same results.
    Thinking about a project without ACTION is just DAY DREAMING .
    103
    Unhappy
    .... I went ahead and tried the Mfg's (ZIRCON) suggestion with the heavier piece of cardboard under the unit as I scanned. It did seem to improve it's performance, somewhat, but nothing to write home about.
    .... What I did to find the TRUE stud position is I used a plywood blade set to a depth of 1/2 on my circular saw and scored the wall horizontally about where I figured the stud should be and compared the penciled marks from before. A STANLEY variable adjustable hand held square with a very thin knife-like blade was used to probe the saw slot on both sides of the stud and marked it with a heavy long black mark on both sides of the stud and with a tiny black mark as it's center. Here are the results (see pics)
    Quote Originally Posted by Boyd Gathwright View Post
    Thanks in advance
    Boyd
    The Heart of Dixie
    4,268
    Funny, I just used the Zircon yesterday and I almost threw it as hard as I could on the concrete garage floor. Useless piece of junk!
    Custom built boats and Kits
    688
    I have the same experience with that useless piece of cr**.
    Here's another entry for your list of what tools really do:
    STUD FINDER - a prep tool for painting. Leads the user to make so many marks on the wall trying to find a stud that he must paint the wall.
    Frankly, I have better luck tapping the wall with a finger.
    in drywall try a "hatpin" one of those "t" shaped pins woman used to use to hold their hat in place.......tap with a finger, hammer or the closest childs head `till you`re close then probe with the hatpin....they actually poke through drywall fairly easily.....tod
    Steve Clardy Guest
    I've had the cheap $20.00 stud finder that Sears sells for about 5 years now.
    It has not let me down. It will pinpoint a stud every time.
    Wake Forest, NC
    292
    I have a $50 Zircon. Don't know the model, but it has deep scan and will scan for electrical. It is supposed to show you the edge and center of a stud so that does help, but like you, I have had it be completely wrong. I would say it is accurate 75 percent of the time. I have seen it do wierd things. It works well enough that I forget to test before committing to the results it gives.
    One thing I have found, making sure you are not starting near a stud and are on the same density of material you are scanning helps some.
    30,231
    I finally had to quit using my stud finder because everytime I was in the same room with it, all it did was point to ME.
    It is obviously faulty. Just ask LOML.
    11,900
    I have a Stanley, bought at Wal-Mart. Don't remember the price. But if I bought it, you know it wasn't very expensive.
    Very reliable and easy to use.
    Steve Clardy Guest
  1. drawing stud walls
    By Dave Willis in forum Designs, Plans and Sketches
    Last Post: 04-18-2016, 08:03 PM
  2. Stud finders
    By Jonathan Shively in forum New Tools
    Last Post: 09-10-2014, 07:14 PM
  3. Stud finder
    By Dan Mooney in forum New Tools
    Last Post: 03-28-2014, 03:02 AM
  4. It's a BOY! It's a STUD! It's a GRIZZLY!
    By Al Launier in forum General Woodworking Q&A
    Last Post: 12-31-2012, 12:35 AM
  5. Stud wall screws
    By Dennis Thompson in forum Carpentry and Construction
    Last Post: 07-20-2010, 05:05 PM
