Results 1 to 3 of 3
Thread: Air Compressor "Intercooler" Question
    Thomasville, GA
    5,992
    I'm interested in adding an intercooler to my air compressor to reduce moisture before the air gets to the tank. I'll use a transmission oil cooler that comes with reinforced rubber hose to use for attaching it to an automobile cooling system. Since the hose is rated for temperatures encountered with transmission oil, will it be safe to use for the line from the compressor pump to the cooler?
    Bill Arnold
    5,319
    What's the pressure rating on the cooler? Automotive transmission oil isn't under really great pressure when it routes through the cooler.
    Thomasville, GA
    5,992
    It's tested at 300PSI.
    Bill Arnold
  1. SIMPLE JIG! turns a "bowl" on "tablesaw"!
    By steve kelly in forum Carving
    Last Post: 11-01-2015, 03:21 PM
  2. "Crime Doesn't Pay" or "No Good Deed Goes Unpunished" ?
    Last Post: 11-21-2013, 05:57 PM
  3. Thompson "V" Versus "U" Bowl Gouges
    By Mike Turner in forum General Woodturning Q&A
    Last Post: 06-25-2013, 01:46 AM
  4. "found" wood question
    By Mike Gager in forum General Woodturning Q&A
    Last Post: 03-20-2008, 03:47 PM
  5. Question on a "Wild Cherry" tree.....
    By John Pollman in forum General Woodworking Q&A
    Last Post: 11-10-2006, 08:07 PM
