Results 1 to 10 of 15
Thread: Pencil Pots
    Cotswolds, UK
    629
    Pencil Pots
    ________Latest customer request____Click on images for larger view.
    ________
    __________
    ________
    _____________________Beech & Ash (85x115mm)
    ________
    ____________
    ________
    ___________________Ash ____________________ Ash & Beech_________________Ash & Beech
    Chas. just a traveller on the road of time.
    Bits & Pieces Gallery
    My Web Site
    Vernon, WI
    230
    Chas those are really cool. I like the Beech and Ash one on the top
    North West Indiana
    6,098
    Those are outstanding Chas!!! Beautiful. I assume you glue everything up before you turn and hollow. Those will create atmosphere in any board room on any board table!!!!
    Jon
    Cotswolds, UK
    629
    Quote Originally Posted by Jonathan Shively View Post
    .....I assume you glue everything up before you turn and hollow....
    Jonathan, I turn, glue and bore out as I go.
    Start with a recessed dovetail base (fully finished on base),
    rough turn and clean up one face of the other pieces, making very sure that the glue interface is flat (squeaky steel rule trick).
    Mount base on chuck jaws, face off front face, bore to required depth if deeper section, clean up edge square, (squeaky steel rule trick again).
    Glue on next section, use tail stock to apply pressure.
    Finish bore to match base, sand and finish, trim outer close to base dia.
    Square off front edge (squeaky steel rule trick again).
    Glue next section etc.
    Finally finish outer.
    Finishing the bore as you go is easier for tooling and finishing.
    My Web Site
    11,831
    Nice looking and nice idea.
    Central Illinois
    936
    VERY nicely done, Chas!
    Bruce
    Bruce Shiverdecker - Retired Starving Artist ( No longer a Part timer at Woodcraft, Peoria, Il.)
    "The great thing about turning is that all you have to do is remove what's not needed and you have something beautiful. Nature does the hard part!"
    10,604
    Really nice idea. I like the last one best. Real hard to choose though
    Cotswolds, UK
    629
    Thanks for the comments, have a few more to do on a similar vein, the underlying reason for the laminating with the current in-work items is to use up smaller pieces, driven I must confess by my inappropriate blank sizing over the last couple of years, which has left me with a totally unbalance stock of blanks for the items being requested. In the case of the ones using spalted Beech it is also allowing me to sandwich a softer less robust wood between two harder wearing pieces.
    My Web Site
    Goodland, Kansas
    4,834
    Beautiful Chas. All of them. Well done.
    Bernie W.
    Way to use up the waste stock on something so nice!
  1. Succulent Pots
    By Jeff Bower in forum Lathe Project Showcase
    Last Post: 06-01-2016, 01:24 PM
  2. more tea pots
    Last Post: 11-13-2011, 01:00 PM
  3. pots
    Last Post: 05-10-2010, 11:19 PM
  4. Weed pots / twig pots
    By Pete MoncrieffJury in forum Lathe Project Showcase
    Last Post: 01-30-2009, 09:35 PM
  5. Potpourri Pots
    Last Post: 12-25-2006, 04:44 PM
