Results 1 to 10 of 30
Thread: whats the differnce
    17,470
    whats the differnce
    between a jig saw, scrool saw and sabre saw..? now the sabre saw is a old description of a tool and so that will be hard to find anyone that has heard that term.. now for the next question, is this saw used that much ? i got asked if i wanted one its a old rockwell with a 12"square table that appears to have a 1.5" cuttin depth. it now has a 1/4" bladde in it with 6 TPI.. this saw is a cast iron version.. whats a fair price for this saw it has approximatly a 16" to 18" throat.
    jig saw/sabre saw= same thing
    scroll saw has the blade held on both ends.
    the old rockwell should say delta/rockwell on the badge?
    the old delta i used to own was much better for marquetry than the modern saws because the blade traveled straight up-n-down instead of in an arc like the newer saws do.
    price? 150-300 depending.
    10,600
    Jig saw and saber saw are the same and hand held. I've also heard it called a bayonet saw. I've seen them mounted under a table.
    5,317
    What Tod said...
    17,470
    any idead where i can go to see this model,, its got a square throat nota swooping c shaped throat and the blade does travel up and down and straight tod.
    3,134
    You can see one right here Larry & you don't have to be to old to recognize all those names & the tools they represent. About the only difference in how it looks is the thoat & there may be a slight size difference but I am not sure about this.
    Bellingham
    2,449
    Larry, how come you put this thread under "General Woodturning Q&A" and not "Old Iron" or General Woodworking Q&A"?
    I am starting to think of some sinister reason, like you have woodturning on the mind or something. You are starting to worry me.
    5,533
    Quote Originally Posted by Bill Satko View Post
    *jedi hand gesture* there is No devious plot involved here
    Larry is Not coming over to the Dark side *
    *these aren't the droids you're looking for
    -Ned
    3,134
    Quick someone send Larry a flashlight he's lost & doesn't know how to get here.
    Larry I have an old King Sealy that was built in 1929. It'll scroll up to 2" thick and has a 24" depth. I use mine quite often to make tight cuts so I don't have to change the blade in my band saw. I think I paid $50 for it.
    It take 8" blades which are not standard for a modern scroll saw so I use coping saw blades.
    I would offer em$50 and see if they bite.
    "Thereís a lot of work being done today that doesnít have any soul in it. The technique may be the utmost perfection, yet it is lifeless. It doesnít have a soul. I hope my furniture has a soul to it." - Sam Maloof
  1. Whats your day job?
    By Ryan Mooney in forum Off Topic Discussion
    Last Post: 12-20-2012, 04:11 PM
  2. Here is another whats-it
    By Bart Leetch in forum Neander Tool Questions and Show & Tell
    Last Post: 10-26-2011, 04:22 AM
  3. Whats next?
    Last Post: 02-05-2011, 02:45 AM
  4. A Red Whats It...?
    Last Post: 12-31-2010, 11:39 PM
  5. Whats in a Name?? or I am who I am
    By Jiggs Elphison in forum Off Topic Discussion
    Last Post: 06-25-2009, 12:38 AM
