Results 1 to 8 of 8
Thread: Clamp loosening up
    Catalunya
    4,632
    Clamp loosening up
    I don't know if this is the right place to post this, if not please move it where it belongs to.
    I have a clamp that is about 35 years old and it has started to get loose.
    If I clamp something to glue it normally it holds but if I clamp something to work on it i.e. planing, it gets loose.
    Is there any solution different from drilling evenly spaced holes on it and putting a pin?
    I do not want to discard it as it is in very good condition.
    Any info will be greatly appreciated.
    Best regards,
    Toni
    30,002
    Toni, I don't have an answer for you, but I've moved your question over to the General Woodworking Q&A area so more folks will see it.
    Bellingham
    2,449
    Kind of hard to understand what the problem is without knowing what type of clamp you have. A picture would be best.
    Toni,
    I am assuming that it is one of the wooden clamps with the 2 pieces of threaded rod used to tighten and loosen. If it is you could get the next size threaded rod Put some handles on it and replace the existing ones.
    Catalunya
    4,632
    Sorry guys, I should have thought about posting a pic of it.
    Here it is.
    Best regards,
    Toni
    Floydada, Tx
    1,941
    Sounds like it is getting worn enough to where it vibrates lose from the planing. Either use it just for clamping or see if you can fill in some of the slop.
    I think the back looks smooth, maybe take a file and cut some grooves in it
    Bob Wiggins is offline Former Member (by the member's request)
    140 miles west of tulsa
    125
    The natural resonance of the machine is probably working against you on this one.
    Before modifying the clamp, if you have access to a material I call shelf liner, a non skid material for motor homes, travel trailers etc., you might give it a shot by cementing a piece on the clamp anvil and swivel to absorb some of that resonance.
    I find that type of clamp to be bad about walking as it is tightened unless it has perfect alignment and this material prevents that a great deal. Once you have used it you'll probably find several uses for it in the shop as I have.
  1. Looking for some clamp on lights
    By Charlie Schultz in forum General Woodworking Q&A
    Last Post: 01-29-2010, 11:34 AM
  2. Bessey tradesman clamp and edge clamp
    By ken werner in forum Old Ads
    Last Post: 09-13-2009, 08:33 PM
  3. The Bow Clamp
    By Frank Townend in forum Jigs and Fixtures
    Last Post: 08-28-2008, 08:59 PM
  4. Another Clamp Rack
    Last Post: 08-12-2007, 12:51 AM
  5. What is your most used clamp?
    By Allen Bookout in forum General Woodworking Q&A
    Last Post: 04-20-2007, 07:41 PM
