Results 1 to 8 of 8
Thread: Replacing belts on my Rockwell 46-451
    May 2009
    Lafayette, Indiana
    2,380
    I'm starting to use my new (33 years old) Rockwell 46-451 lathe and have been hearing the belts sqeaking alot. Everything is working just fine (reeves drive works well) but I want to replace the belts. I noticed tonight that one of them still has the Rockwell part number on it from when they were new, so these are the original belts that came on this lathe back in July of 1977 when this lathe was built. The manual I have says that they are 65 OC and 37 OC. I'm not sure what OC stands for??? I'm assumming that the belts are 65 inches long and 37 inches long. Would I be guessing right here?
    Tom
    11,830
    BeltS? Plural? On a Reeves drive? I would like to see a picture of that set up. Yes, any belt after all these years is wanting replacement.
    Tellico Plains, Tennessee
    4,351
    Quote Originally Posted by Tom Baugues View Post
    Tom
    See my reply to Wes's problem... if you need belts, check out the belt store.
    Chuck
    Tellico Plains, TN
    May 2009
    Lafayette, Indiana
    2,380
    Here you go Frank. This is the Reeves drive pulley setup inside my Rockwell 46-451 lathe. Belt on left goes down to the motor and belt on right goes up to the headstock spindle pulley. It all works very well. I just think that the belt going down to the motor is dry and is the cause of the squeaking.
    Thanks Chuck for the link to the belt store. I should be able to find something here locally I'm sure. I was just unsure what the "OC" meant in the manual. Maybe it means "outside circumference"? I'll just take it off and take it with me to be sized.
    Tom
    30,014
    My Sears lathe had two belts, too. One from the motor to the Reeves drive shaft, then the Reeves drive belt itself.
    Cotswolds, UK
    629
    Tom, try giving the belts a squirt of PTFE Dry Lub, never caused any problems with my reeves drive lathe when I had it, quitened the drive down no end and did not result in slip.
    Chas. just a traveller on the road of time.
    Bits & Pieces Gallery
    My Web Site
    11,830
    That's too simple. I knew that.
    11,830
    Tom
    OK, interesting set-up. Thanks for pics.
  1. Replacing the closet
    By Rennie Heuer in forum Carpentry and Construction
    Last Post: 02-16-2016, 11:59 AM
  2. Replacing the fence
    By Chris Mul in forum Carpentry and Construction
    Last Post: 09-13-2010, 01:47 PM
  3. New Belts
    By Chuck Ellis in forum Hot Deals
    Last Post: 12-17-2009, 05:28 PM
  4. attic fan might need replacing
    By Frank Fusco in forum Carpentry and Construction
    Last Post: 09-02-2009, 01:55 PM
