Results 1 to 10 of 18
Thread: End Grain Maple Calabash Bowl
    Oct 2007
    Harvey, Michigan
    687
    This Maple bowl is 10 diameter x 5 high with walls at 1/16 thick. The bottom of the bowl is or slightly thicker to give the bowl some weight. Sanded to 320 and has the first of several coats of Minwax Gloss Wipe-On Poly.
Name:	Maple Calabash Bowl v1.JPG
ID:	37837 Click image for larger version.
Name:	Maple Calabash Bowl v2.JPG
ID:	37838 Click image for larger version.
Name:	Maple Calabash Bowl v3.JPG
ID:	37839 Click image for larger version.
Name:	Maple Calabash Bowl v4.JPG
ID:	37840 Click image for larger version.
Name:	Maple Calabash Bowl v5.JPG
    The bowl was quite a challenge to get clean undercuts. I did hollow this in stages and that helped keep the bowl stable.
    As always, your comments, critiques and opinions are welcome.
    Thanks for looking!
    Steve
    Steve, yet another beautiful piece of wood that you have done proud!
    I'm really going to have to get my lathe out from under the stuff that is piled on it
    30,014
    Very nice, Steve. A little on the thick side, but it'll do. Jeff Bower might have some pointers for you on thinning it up. (And you both know I'm kidding.)
    Man, it's almost like we're twin brothers from separate mothers...
    http://familywoodworking.org/forums/...ad.php?t=15882
    10,604
    Beautiful, as usual
    Jul 2007
    Des Moines, IA
    854
    Steve, wonderful work as usual. I think I need more practice.
    Jul 2007
    DSM, IA
    5,719
    Ummmm, Steve, just one more cut should do it.
    Beautiful bowl Steve.
    My Website
    Tellico Plains, Tennessee
    4,351
    obviously I'm missing an inside joke or just clueless.. maybe and probably both.
    I like the form... still working on getting my walls down to that thickness.... after that cherry piece blew up last summer and about 1/2 the bowl hit me in the chest, I'm still a little gunshy about really thin... working on it though.
    Chuck
    Tellico Plains, TN
    Oct 2007
    Harvey, Michigan
    687
    Red face Measurement way off!
    I went down to the shop this morning to check and see if the bowl was dry enough for a second coat. It was but in the process of handling it I thought it was WAY too heavy for a 1/4" bottom. I mean, Maple can be heavy, especially after a couple of saturation coats of oil or poly - but this was way more than I expected.
    Grabbed my measuring stick and checked the bowl and was honestly shocked to find that the bottom of the bowl was not the 1/4" as reported but it was 7/8"! What the? How in the world did that happen? Well that sure accounts for the weight!
    Got to thinking about it and when using a laser point system you have to watch the dot on the wood while turning. When the dot falls off the wood - you have reached your preset distance. I had the distance loosely set for 1/4" as I knew I would lose a little wood from sanding inside the bowl as well as when I removed and sanded the tenon area. What I didn't pay attention to was my viewing angle!
    With the diameter of the turning, the steep angle of the bottom of the bowl - combined with my height - I was viewing everything from a skewed angle (cause I did not want my face in the line of fire) and I stopped when I thought it was about 5/16" thick instead of having the laser dot fall off the turning. I should have stopped turning and just used the laser to take a static measure of remaining depth - which I normally do on hollow forms! Nope - I knew what I was doing! Yeah.... right!
    So - now I either accept that I have a heavier than anticipated bowl or figure a way to get it centered on the vac chuck and turn it down to where it should be! Ah........ the pressure!
    Vaughn - nice looking bowl! But I have to point out 2 things - you get to be the brother played by Danny Devito and mine is bigger by 1/2". I do think your bowl has a lot of character and the contrast of the dye work with the exterior of the bowl works well!
    Chuck - Jeff has turned some great looking yet seriously thick bowls!
    Steve
    Catalunya
    4,632
    If anytime I take the plunge to the spinny vortex Steve, you and your pieces will have part of the blame, together with some other great stuff from other turners fro this forum
    Best regards,
    Toni
    Los Angeles, CA
    2,668
    I see your work and wish I could be turning right now.
    Nice job.
  1. Calabash
    By Phil Stivers in forum Lathe Project Showcase
    Last Post: 10-02-2015, 03:11 PM
  2. Calabash - Good Video by Lyle Jamieson
    By Ted Calver in forum General Woodturning Q&A
    Last Post: 09-06-2015, 06:34 PM
  3. 2 recent turnings - maple bowl, square quilted maple platter.
    By Chip Sutherland in forum Lathe Project Showcase
    Last Post: 04-03-2013, 03:22 AM
  4. maple end grain staining
    By Julio Navarro in forum Finishing School
    Last Post: 03-08-2012, 01:26 PM
  5. open grain vs. closed grain hardwoods
    Last Post: 04-09-2011, 02:35 AM
