Results 1 to 10 of 26
Thread: Bandsaw - Grizzly vs. Delta vs. Jet
    I am thinking about getting a 14" band saw for the shop ... don't have a tonne of money to spend and I've been looking at the following 3 models. I'd like to hear thoughts on which is the best deal or which people think I should go with for one reason or another.
    Also, does this Grizzly band saw ever go on sale? Should I hold out until it does (on Amazon or their site directly)?
    #1 - $399 Delta (model #28-276) 3/4 HP available at Lowes. I don't think this comes with any fence. I could pick this up at the store so no shipping.
    #2 - $435 + shipping (approx. $510 total) Grizzly 0555. 1HP Comes with fences and everything I think I need to get up and running. Riser block available for only $70 more ... quite a bit cheaper than the Delta.
    #3 - $550 + shipping Jet 14" 3/4 HP. I don't think this comes with a fence or mitre gauge.
    I'm leaning towards the Grizzly at this point. I am located in New Brunswick, Canada so the best option would probably be to have it shipped to an address in Maine and then drive over and pick it up. Anyone have any shipping addresses or other options of how I might do this? Are there any Grizzly resellers in Maine or do you have to order off the web?
    Thanks.
    I just went thru the same thing your doing and ended up buying the GO555. I think you get the best bang for the buck with that bandsaw. Plus it has 2 speeds. Very smooth running and the base is rock solid.
    30,008
    Of those three I think I'd go with the Grizzly, too. They have a good reputation...not the best saw in the world, but great performance for the price. Seems like a very solid tool with good service if something does go wrong.
    I don't have any advice on the shipping and delivery question. I do know Grizzly doesn't have any resellers (anywhere), although they have a sister brand, Shop Fox, that is sold through tool dealers around the US. I don't know if there are any Shop Fox dealers in Maine, and couldn't tell with a quick Google search.
    Shop Fox makes a 14" bandsaw (the W1706) that's similar to the G0555, but has a few upgrades. I have one, and when I bought mine I was looking very hard at the G0555, but by the time I included the mobile base, riser block, and shipping, it was only about $50 less than buying the Shop Fox from a local dealer.
    11,828
    Grizzly claims the G0555 is the biggest selling bandsaw in the world. Dunno how accurate that is. But, I am very happy with mine. As you found out for yourself, you get the biggest bang for your buck from Griz. On the same budget, I would make the same choice again. With more budget, it would be the 'X' model or I'd jump up to a 17" 'X' model.
    You might be in luck, Griz often has a Christmas sale, about 10% off. Dunno if this item will be one in their catalog but since it is so very popular, I'm guessing it probably will be.
    Thanks Frank, I'll keep an eye out for any Christmas sales.
    Do you guys find that the 6" riser is really nice addition? Do you find that you need the extra height quite often?
    Sep 2009
    Midlands of South Carolina
    271
    Also going to be looking at bandsaws...
    Does the riser make the saw less stable? I would think it would be better to get a saw that was already as big as you need (space wise), rather than having to extend a shorter one? Maybe there is a big cost difference?
    11,828
    Quote Originally Posted by Rick Prosser View Post
    You are right on all counts. Bigger is better. Small with riser might be less rigid. Bigger also means big cost difference.
    Is the riser really a good thing? I'll let you know when I unpack and install mine. Only had it six months.
    5,320
    Rick, (and Dawson, too)
    You make a good point. I have a Laguna 16, with 12" resaw capability, and also a TaiChi 14" - no riser - and 5" resaw capability.
    My relatively limited experience with 14" saws with risers on them is that: (1) they tend to be a bit 'springy' in the frame when the riser is added; (2) they're much more top-heavy, and more prone to tipping unless they're on a wide base; and (3) they're under-powered.
    For an only slightly higher price (currently $795, plus shipping) the Grizzly G0513, with 17" throat and 12" resaw capability is sure worth looking at. It has a 2 hp motor, and a bigger table, sits on a solid base, and is quite stable.
    You can always run thin blades on the big saw, but you really can't run the wider (+) blades on the smaller one. The G0513 with a " Woodslicer blade will cut 1/8" veneer all day, with great results.
    Floydada, Tx
    1,941
    What ever you buy, make sure it is a even sized saw. I bougth the grizz 17" and now regret it as I have to order tires and other things thru them. Cant run down to woodcraft and pick up a blade if I snap one.
    30,008
    I've only used my 14" saw with the riser, so I don't know if any flex was added because of it, but for my uses, I couldn't do without the riser. At least half my cuts seem to be deeper than 6". While most of my cutting has been bowl blanks and such, I've also used a 1/2" Woodslicer and resawn workable 1/8" veneers on it.
    I'd love to have a bigger steel frame saw (and hope to have one in the future), but this one has done well for me. At the time I got my saw, the cost difference was enough to sway me to the smaller saw with a riser.
  1. Delta 35-7670 Stacked Dado Set $75 + s/h from Grizzly
    By scott spencer in forum Hot Deals
    Last Post: 11-22-2012, 04:27 PM
  2. Grizzly G0555XL Bandsaw on Sale
    By Vaughn McMillan in forum Hot Deals
    Last Post: 10-28-2012, 12:41 PM
  3. Grizzly bandsaw on special this week
    By Cynthia White in forum Hot Deals
    Last Post: 03-29-2011, 10:15 AM
  4. An update on the Grizzly riser on a Delta saw
    By Chuck Ellis in forum Off Topic Discussion
    Last Post: 02-19-2011, 12:47 AM
  5. Grizzly bandsaw adjustment
    Last Post: 08-16-2007, 07:57 PM
